grease or loctite?
15K views 33 replies 15 participants last post by  D Bone
#1 ·
This is a real noob question, I know. Apologies in advance. I thought that if something is supposed to move (freehub, bearings, etc.), it should be greased. If it's supposed to stay where it is, and if it has a thread, you may use loctite.
If so, why is it then that my LBS guy is putting grease on every thread he can find (bottom bracket, thru-axle, etc.)? I am sure there is a good reason, and I am simply too ignorant to see that. Please enlighten me!
#2 ·
When properly tightened to the recommended torque, all those parts should stay put just fine, the grease is there (and recommended) to prevent parts from seizing together and to a lesser extent, to keep them from creaking, to prevent possible corrosion, minimize galvanic reactIons between dissimilar metals, etc. You may also see some people use antiseize paste too for the same purpose (although this is way messier than grease). Since you can use a lot of grease too, it can sometimes act as a seal or barrier to prevent water or debris from getting into something, whereas with loctite, you only use a few drops. A lot of people don't service their bikes very frequently and expose them to very harsh conditions... Last thing you want to happen is having to throw away a frame because you can't remove this or that part.
I only personally only use locktite on my bike on a few small suspension pivot bolts and just because it's recommended for those spots by the manufacturer.
#9 ·
All of the above and I'll add that greasing fasteners minimises friction which can add a considerable amount to the torque value and result in an under tensioned fastener.
I've noted Shimano recommend inspecting through axles every ride so covering their rears to that degree there's probably something in it.
#10 ·
I do a pre-ride torque check before every other ride. I grab my 4,5,6mm triangle hex head tool thingie and start at the front of my bike, work my way through the linkage, cranks and chainring and finish off with the RD. Then I check each Maxel (although I orientate the levers in such a way that a visual inspection is enough).
Sounds hard, but the whole thing takes under 60 seconds............... I have never been 'that guy' on a group ride that has a bolt fall out, stops the group and needs help just to keep going - Never have, never will.
#16 ·
One thing to consider when torquing bolts . is the quality of the bolt. cheaper offshore bolts will stretch and fatigue over time. sometimes it pays to inspect and replace bolts that somehow come loose over time.
I will use loctite on most small bolts. I usually put anti seize on larger fine threads and torque them down. ie threaded derailleurs or bottom brackets that get allot of water and mud exposed to them.:)
#17 ·
1k KM and the OP hadn't re-checked his bike bolts etc :rolleyes: Lucky as hell something more/worse didn't happen. I grease most everything, stops bolts binding when torquing and allows you to torque to proper tension and stops seizing of differing metals/alloys, sometimes use anti seize on certain parts/bolts, never had a bolt come loosse because of it.
#20 ·
Frankly, it seems to me that the old quick-release were safer than the current thru-axles. In the old System, the bolt had some machined contour that would help keeping things in place despite vibrations, thermal Deformation, etc. At least in my thru-axle, it's just a threaded screw. No wonder it gets loose - particularly if greased. From the viewpoint of tightness, methinks it's a step backwards.
#31 ·
Now this sounds entirely logical and agreeable. It's not like I do not do any once-over: I ride 600 vertical meters/day (and often 2x600), and I check brake pads daily, and rotor thickness monthly. The front brake pad (the Shimano metal with heatsink) lasts for ca. 20'000 vertical meters, the rear pad a bit longer (25-30'000m).
It did not occur to me to check the thru-axle as frequently - mostly because the old axle never required that. But I now understand that that thru-axle (and her friends) may have taken offense at my glib remarks, and apologize meekly to her.
