Freehub on my newish (~ 1.25 year old) 2019 Sirrus X Comp Carbon suddenly broke!
9.8K views 9 replies 3 participants last post by  mikemccand
#1 ·
Hello, first post!
I bought a Specialized Sirrus X Comp Carbon ~1.25 years ago (April 2019), and have ridden it lightly, loving it, maybe ~700 miles total.
But on my last ride last week, on a hard down stroke, something in the drive train suddenly skipped, and then the bike started making an ominous grinding/scraping sound when coasting. I took the wheel off, and found that my freehub no longer freely "coasts". When I rotate it by hand, it is catching hard, at the same angle on every rotation.
I think I could have this fixed under the 2 year Specialized warranty. But my LBS is swamped (unexpected side effect of pandemics!) and would be a few weeks before they could even look at it.
So, I would like to fix it myself if possible, but I am now stuck and have some questions. I'm hoping the experts here might have some answers! Thanks in advance:
  • Has anyone else seen their freehub act up like this on their Sirrus?
  • Does anyone know the part number, or even just defining specs, of the existing freehub on 2019 Sirrus X Comp Carbon? I see Bear Pawl and "HFH-0013" etched on the freehub case, but I cannot find any obvious matches with Google.
  • Does Specialized sell service manuals that wouldd give me specifics like true part numbers, what tools I need, and how to disassemble/reassemble the rear hub?
  • Any recommendations for a more durable and matching freehub? I would like to upgrade this part if possible to reduce chance of it failing again.
Thank you for any and all ideas. I'm stuck and I don't have a backup bike, during the best biking season around here (Massachusetts), boo.
Mike
#2 ·
If you have the cash, I'd just upgrade the wheel to something better. Make Specialized deal with the warranty and when they fix or replace it, you'll have a wheel that you can sell, put on a in indoor trainer, or keep around as a spare.
There are a ton of great options out there. Hope, Industry 9, and DT Swiss hubs are known to be very reliable. check out Hunt Wheels and Boyd as well.
Do you have this 2019 model? the 2019 model appears to have generic hub. they probably made running changes in production, which is common. unfortunately, there are tons of generic hubs on the OEM market that don't offer replacement parts. with a blown freehub, you have to use the specific freehub made specifically by that manufacturer for that hub. there is no universal standard for freehubs-far from it. once the freehub goes, unless Specialized can find the right part for you, the wheel is really a loss.
if that's right, you're looking for a 700C rim with something like a 21-25mm internal width, a Centerlock rotor (or get the more common 6-bolt option and buy a new rotor, cheap), a 142x12 axle (not boost 148), and an HG freehub (not XD or Microspline).
Since bike shops are so very backed up, you might contact Specialized directly and ask them. maybe the can expedite the process.
#4 ·
Wow, thank you all for the quick replies!
I like this idea, and probably could afford it. Does the rear wheel come with hub/freehub? But not the disc brake rotor, so I would transfer mine over (or switch to new 6-bolt rotore as you suggested)?
Should I replace both wheels or just the rear one?
Oh sorry I meant to say the SKU before -- I have the 90919-5205, which I cannot find at http://specialized.com, weird and annoying! Here's an example of my bike (out of stock)
Looks like a different model from the one you found (80919-5102), but very similar.
I wish Specialized documented precisely the specs of parts on all their bikes so I could just go and look it up to find exactly the right new rear wheel (or freehub, etc.) to purchase.
Ugh, it's too bad freehubs are not better standardized. Running changes in production is especially frustrating :)
OK I will try asking Specialized if they can suggest a compatible new wheel, or at least confirm the specs I should match -- seems likely to be the specs you found from the above model. Or maybe I'll just bring my current wheel to my LBS and see if they can match that.
Thank you! At least I have a path forward now...
#3 ·
Pull the cassette off and inspect what is broken. (Don't need a cassette tool. I'd imagine you will be able to see what's wrong just by taking it off and looking at the bottom). I'm guessing it is a re-branded DT Swiss 3-pawl freehub that is commonly known to fail. If this is the case, specialized will cover it under warranty. But like you said, that could take weeks with how busy the bike industry is.
The previous reply had a good suggestion on buying a new wheel and getting this one fixed as a spare or just selling it. Otherwise it the freehub looks like the one below, you can just buy a new one of those and be up and running in a few days. Just make sure you get the correct one, there are so many different combinations due to all the different bike industry "standards" these days.
#5 ·
I have managed to pull the rear gears (is that the "cassette"?) off, but the freehub is still attached and I cannot figure out how to remove it :) YouTube videos seem to suggest a 10, 13 or 15 mm sized hex wrench should fit and rotate (hard) to unthread it, but my freehub seems not to be attached like that.
I have not yet managed to remove the rotor (on the other side of the wheel), and ordered some Park Tools that I think will match and let me remove that.
Anyway, I do really want to take the existing freehub apart to understand how it failed.
Thanks for the pointer! Yeah, matching the actual specs of my current freehub is incredibly tricky! I emailed Specialized to see if they could even tell me what those specs are, how to find (upgraded) replacement freehub, etc., but I am not hopeful on this route given what @mack_turtle described about freehubs not being very standardized / changed during production.
It is also very disturbing to me that I cannot even locate the exact bike that I have (the SKU) on the Specialized web site. They really should at least make the rough specs of the components available.
#8 ·
Another update! I went to LBS and bought a wheel matching those specs, transferred my rotor over, re-attached the cassette gears, and mounted on the bike, and it all seems like it will work!
I still need to take bike on test-drive to confirm, but I think I am back in business, and will go biking tomorrow for real.
Thanks @mack_turtle and @RBoardman.
I will keep trying (at lower priority) to remove the broken freehub off my old wheel and replace it to have a spare/backup.
#9 ·
"disc specific" assumes you're going to want some sort of brake on the bike and the rim in question does not have a thick, flat, even surface to use a rim brake on it. that rim is only useful in applications where a disc brake is used. installing it on a bike with rim brakes would cause lousy braking and might even be dangerous.
