Flipping your stem
22K views 76 replies 31 participants last post by  hdparrish
#1 ·
How common is this? How many of you are riding a bike that you've flipped the stem on?
Signed, Curious
#3 ·
Looking at my past bikes (5, one is my road bike) all have flipped stems. Fit and performance drives this choice not looks. I am an xc biker not trail, downhill, etc. I like to push myself and go as fast as I can. I feel getting a lowered position when dialed in with all the other things that gives a proper bike fit allows me to climb better while not losing on the descents. So much has to do with frame size, tire size, etc. etc. that is a rough question to answer but I think you know that.
#4 ·
I have flipped the stem on one of my bikes because I like the resulting bar position better.
Keep in mind that most of the time when the a stem is flipped it's not obvious because due to the steerer tube angle the stem will still slope upward from steerer tube to bar -- just at a more shallow angle.
Is this a trick question and I missed something...?
#6 ·
I flip the stem down on every bike I own, always have.
The reason: Long, steep climbs here are unavoidable. Having the bars down a little bit helps going up for prolonged periods but it doesn't hurt going back down.
However: This works for me and it may not work for you, or you, or you, or any of you.
#13 ·
Try it again.
Flip the stem with spacers = regular stem below spacers.
You can get to your needed bar drop many ways.
FP, I know,you know this but others might not have thought of this.
I personally change stem positions for different courses, both hight and length.
I flipped, instead of slammed, my stem so I could still mount a gps on the stem....because I don't want to cut the steerer too short if I want to go back or maybe even sell the bike.
#11 ·
#17 ·
I flipped my stem. it was pointed down and how it's pointing up. but if it was pointing up and I flipped it down, I would get a different result. does anyone else realize how non-specific and silly this discussion is?
"flipping" your stems means nothing. we should be discussing overall handlebar height, which is a result of bar rise, headtube length, and stem dimensions. it has no bearing on whether the stem is pointed up or down.
discussing which is better is like trying to decide what the "best crayon color" is. it's all a matter of personal preference.
