I don't have a bike with through-axles, and the articles online are all BS articles that talk about "what through axles mean for you", or complain about standards proliferation, and they don't actually talk about the nerdy technology or the specs.
Through-axles are hollow aluminum, right? Anyone know how big the hole is through them?
Do the inner races of the hub bearings run directly on the through-axle? If so, it must require pretty close tolerances for the axle to avoid fretting or sloppiness--does anyone know what the tolerances actually are? Is there any problem having the steel bearing races running on the aluminum through-axle? Are you supposed to grease the axle?
Do they get tight from screwing into the opposite dropout, or is there a cam mechanism like a QR to make them tight? In the pictures, it looks like the axle first screws into the bike until it bottoms, then it gets tightened with a cam. Is this right?
Are the threads replaceable? Like what happens if your frame strips out?
THE BIG QUESTION: Normally, in order to "squeeze" the wheel into the bike, something has to oppose the squeezing force, or else the bearings will bind. On a QR hub, whether it's sealed or cone bearings, the bearings are locked to the axle by the machined axle. But then the axle won't slide through the bearings. To have the axle slide through, you would need a spacer inside the hub between the two bearings, so that when you tighten the axle, the bearings don't bind. This is like the spacer that goes between the BB bearings on BMX cranks. Is there a spacer like this inside the hub to take up the space between the bearings?
