Dt Swiss 54t ratchet upgrade -my experience
97K views 120 replies 47 participants last post by  scottzg
#1 ·
I have 2 sets of DT Swiss hubs 240s and 350 both with 36T. I recently upgraded to 54T. Its well worth it. I was a bit skeptical it would make or feel a difference.
Easiest install and money well spent. Noticed climbing was easier and allowed me to stay in a higher gear on my familiar local trails.
Plus now I can make noise like those guys on CK hubs and I9's lol
#4 ·
Just found my answer here:
DT Swiss Ratchet 54t Upgrade kit, will triple the amount of engagement points of your stock star ratchet 18t hub. After installation engagement of your hub will only take 6.6° of pedal movement vs the 20 deg; of the stock 18t setup. This kit includes everything you need to make the swap in minutes including two star ratchets, two springs and DT Swiss' specially formulated Molykote grease. Upgrade fits DT Swiss' 190 ceramic, 240, 350 or 440 hubs.
DT Swiss 54T Star Ratchet Upgrade Kit > Components > Wheel Parts > Freehub Bodies | Jenson USA
#12 ·
Has anyone found the 54T upgrade for under $95 anywhere? Thats seems quite high seeing my entire rear Spline2 wheel was under $150. These should be closer to 50 bucks for what it is imho. :madman:
#13 ·
i don't disagree, but at the same time you are lucky that you even have the option to upgrade IMO. how many other hubs have a simple, easy, affordable upgrade option available?
it's a lot better than having to build a new wheel.
#19 ·
as many other people have said in the past, and i agree, the most important thing is to get away from that 18 POE number. the 36 upgrade is a nice compromise of cost/benefit. the jump from 36 to 54 is less dramatic.
#20 ·
What are the long-term reports on the fake 54T upgrades? Thought there was a thread here but it may have been a different forum.
#21 ·
There is a fake upgrade option?
I just upgraded my geared wheel set with the 54t ratchet. Super simple and I actually want to ride my geared bike now unlike when I had my 15* engagement AC hubs on it. 20* engagement was a complete non-starter. Honestly, I'm not sure why DT doesn't fit at least the 190's with the better ratchet. Maybe put the 54t in the 190's, the 36t in the 240's, and the LB 18t ratchet in the 350's.
#23 ·
I just upgraded my geared wheel set with the 54t ratchet. Super simple and I actually want to ride my geared bike now unlike when I had my 15* engagement AC hubs on it. 20* engagement was a complete non-starter. Honestly, I'm not sure why DT doesn't fit at least the 190's with the better ratchet. Maybe put the 54t in the 190's, the 36t in the 240's, and the LB 18t ratchet couple in the 350's.
It was a couple of pages back with mixed results. And 48T, not 54.
http://forums.mtbr.com/wheels-tires/48t-star-ratchet-%2460-ebay-dt-swiss-240-350-a-940469.html#post12700235
#24 ·
So is the 54t upgrade noisy? The reason I went with DT Swiss is because they are quiet. Is the 36 tooth upgrade noisy?
#33 ·
How much do you ride? I don't think I've ever really worn out any of my wheel bearings...including the ones on my road wheels which have some 6k miles on them.
I've got a set of DT 350's and the bearings are pretty smooth. I mean my wheels can spin for a fairly long time when I spin them on the stand.
#34 ·
I avg 40-60miles week on the trail in socal's dusty dry sandy conditions. I probably just need to clean the bearings. It doesnt spin for that long but i dont hear any grinding. I was just wondering what ppl have done
Sent from my SM-G930V using Tapatalk
#35 ·
depending on how much your current bearings are dragging they could be shot, or at least need servicing.
the stock bearings are good quality bearings and are known to be durable and spin really well. if you're going to replace them because yours are shot i would stick with the stock bearings.
if you want to "upgrade" you can move up the ABEC scale. I recently replaced the bearings in my hubs (not 350's) with ABEC 5. they're made to higher tolerances so supposed to be higher quality, last longer, spin better. you can go higher up the scale, ABEC 7,9,etc. but the higher you go the less improvement you get and the higher the cost. based on my research you quickly reach a point of diminishing returns. ABEC 5 is a good jump in tolerances and only a marginal cost increase, sweet spot for me. instead of $6-8 for the stock bearings I think i paid $12 ish?
ceramics are stupid expensive and not worth the cost IMO.
#36 ·
There are several things you can look at. Consider servicing your bearings with a lighter grease. I like Buzzy's Slick Honey as a dependable, lighter lubricant. There can be a trade off here that can mean increased service intervals, but with a lower coefficient of friction. Another consideration, (at least for the rear wheel) is the frequency and type of lubricant being used on the freehub or star ratchet. In the summer, I use Dumonde Tech freehub grease, but in winter the Dumonde freehub oil. The oil is lighter and can offer reduced friction and greater free-spin.
I have ceramics in my BB, and have been very happy with them, but for me personally, I'm not sure the price can be completely justified in all applications.
