Do I need to worry about this damage to my carbon frame?
4.8K views 19 replies 16 participants last post by  turnerbikes
#1 ·
On a ride today a stone got wedged between the crank and the frame and has damaged the frame taking off some paint and cutting into the carbon.
The cut into the carbon is about 1mm deep.
Is that bad enough to require repairing or is it just cosmetic?
#2 ·
No one is going to be able to give you a definitive answer just looking at a picture. But if it were my bike I would not ride that, its just not worth the possible injury if it snaps. If it were my bike, and not under warranty, I would just get a carbon repair kit and fix it myself. I don't think its bad enough that you need a professional repair.
#4 ·
I was thinking the same thing, until I watched this:
Guessing the repair kits might be a little more straightforward. Anyone try one or have a rec?
Given how close cranks are nowadays to the frame, I'm guessing this type of damage will become fairly common.
#11 ·
Hard to be confident from a picture but I don't think I'd worry about it. If it were my bike I'd be sad about the scratch but wouldn't have any serious concerns about its strength and would happily just ride it. If you really want to do something to it you could dab a bit of epoxy resin in there. I think a repair kit is probably overkill.
#17 ·
pretty gnarly scratch, but I doubt your chainstay is going to snap because of it.
Unless you have some experience working with composites or are willing to potentially waste a lot of time and money on a DIY repair that might make it worse, I'd suggest paying someone reputable to fix it. Just dabbing epoxy on it may help cosmetically but does nothing for the structure.
working w/carbon fiber isn't terribly hard, but there is a lot to know and some real skill involved in doing it right.
#20 ·
Ride it often, ride it hard and don't worry about it when you're riding. BUT, regularly watch the ends of the gouge for a crack to start migrating. Keep these original photos for reference. If you see anything that looks like a crack creeping away from this gouge have it professionally repaired. This kind of repair is easy, cheap and there are carbon frame repair shops in every city in the USA. If you really want to keep the price down, don't try to match the fancy paint, just spritz it with flat black from a rattle can and put a Clash sticker on it.
