Perhaps I'm a fastidious proponent of preventive maintenance, or maybe just OCD. Regardless, periodically I like to disassemble the freehub, clean it up, and relube everything. Recently I got a pair of I9 hubs, and now they have enough miles that maintenance is prudent.
I watched the videos and half-heartedly tried it on a couple occasions. But those end caps sure do seem like they're welded in place. Yesterday I talked to the mechanic at the LBS, and he confirmed that sometimes they're ridiculous to take apart. So tonight they were coming apart--one way or another.
Then I remembered a gift from my wife a few years back. I'm a tool whore, so sometimes a tool will sit on the shelf for years between uses. Such was the case with my bearing extractor kit.
I got the correct size extractor from the box, set it up, and screwed the slide hammer onto it. BAM! BAM! BAM! And apart it came.
This is an import that costs about sixty bucks. A GOOD kit would probably cost hundreds. But the frequency with which I use this probably means it will last the rest of my life. So if you're an I9 kind of rider, you might want to get the correct tool rather than bugger up your hubs with pliers.
