Direct Mount stem
21K views 22 replies 11 participants last post by  cmc4130
#1 ·
Alright guys (and girls) direct mount stems. What are the pros and cons? They're pricey so its not like I can go buy one and test ride it. Any help would be appreciated.
#21 ·
the handle bar is the point where the flex comes from its whats creating the flex, you need larger points to connect the 2 sides of the bar together for it not to flex. you have 4 axies the handle bar only stiffens up side to side movement. what about up and down twisting is you have 2 lateral points of contact that are not connected. that allows for twisting
#11 ·
Yes, a DM stem can give you the lowest bar height. However, a DM stem and a riser crown can only get so high...meaning a conventional stem can give you a higher bar height.
$45 shipped on the sunline stem is a steal!!
Also the eccentric Point One stem is still not available...kinda like the rare Thomson DM stem.
#12 ·
I'd go for one of these.....
pointoneracing.com
these are pretty notiorious for not being stiffer and having a ton of flex to them. yes they look cool and are very light but bar flex sucks.
the new renthal stem is badass. its a great price and looks cool. the twenty 6 dm is a great stem. very pricey though. but have colors to match any bike. if you want just a basic but very reliable dm the truvativ stuff has always been great
#2 ·
From how I see it
Pros:
lighter
stiffer
won't twist (see neg for the bad of this though)
no need to align it
Cons
In a bad crash the force has to go somewhere like crowns or bars
expensive?
With DC forks being stronger these days I don't see any reason not to go with a direct mount stem. Just better in all areas (including looks) IMO
#4 ·
From how I see it
Pros:
lighter
stiffer
no need to align it
Cons
expensive?
I never considered where the force might end up in case of a crash.
