It seems that most of the rebound damping threads, videos and documents are focused on how to set it rather than the outcome you're after ... the goal. And the standard test where you push down on the bars, lift up and watch the fork seems a little vague. I mean, what exactly does it tell you?
(To keep things simple, let's assume you have sag, travel and compression damping dialed in.)
THE GOAL
Simply put, rebound damping should smooth out the trail chatter. You should glide over smaller imperfections and feel more connected to the surface. If you feel evey little bump and your fork is pogo'ing, then you don't have enough rebound damping. Once you smooth out the ride, however, you'll be able to crank much more efficiently--all of your energy will be focused on forward motion--so it's a worthwhile goal, IMHO.
Obviously, I'm not the first rider to come up with this concept. In fact, it was mentioned in a thread on 3/12 but that discussion died a quick death. But I think it's a pretty important topic--many of us have these fancy forks which can really enhance our riding experience but may be a little unclear as to what we're supposed to do with them? And expressions like plush, bobbing, compliance, IMHO, seem inadequate when describing what we're after
So smoothing out the chatter, gliding over the trail and feeling more connected ... is that what we're after?
DUAL AIR DIFFERENCE
If your fork is equipped with a negative spring, then you have the ability to speed up your rebound over an SA fork by running less negative pressure. Specifically, if you run the same positive pressure on a DA and SA fork, lower negative pressure in the DA produces faster rebound.
Have you ever pulled a wheelie and heard a clunk from your DA fork? If you have greater pressure in the negative spring, you probably haven't. But if you run less negative pressure, the fork will launch the front wheel downward with enough force to make it sound like something's loose in the steerer.
The lower negative pressure allows your fork to rebound quicker than an SA fork which is a benefit at higher speeds but it also means that you'll need more damping to minimize the chatter, e.g. I have a SID and the rebound knob makes three full turns from stiff to soft. To smooth out my ride, my fork is set only 3/4 turn out from full stiff.
While it might seem extreme, I definitely encourage anyone with a DA fork to drop the negative pressure. Bleed out all the negative pressure, in fact, and see how it affects your rebound. Then play with the rebound adjustment and see how far from the middle setting you need to go to smooth out your ride. Again, I'm not the first rider to come up with this idea--the SID tuning guide recommends negative pressure from 40-70% of positive for XC racers--but it seems like the affects of such settings are rarely explored.
WRAP UP
FWIW, I do most of my riding on loose to semi-packed trails without a lot of big hits, drops or bumpy descents. I imagine that the reduced chatter goal carries over to some extent but I'm definitely no expert when it comes to DH or AM riding.
Thoughts? Corrections? I'm here to learn and share like the rest of you.
THE GOAL
DUAL AIR DIFFERENCE
WRAP UP
