CST Ouster - followup
Thanks for the review on the Ouster. I've seen ads for this tire in MTB magazines so I just ordered one for a trial (29, 2.25"). The claimed weight was just north of 700 grams which I don't think is too bad for this style of tire. If it works well for rocky desert trails I'll be stoked because I hate paying $50+/ea. for tires.
Edit: Set it up tubeless but it was kinda a PITA. I had to air it up (on an oem 19mm IW Giant wheel) using a tube and leave it out in the sun while I was at work. I used 2 layers of fresh Gorilla tape and a Stan's long valve as my base, and I think the tape layer interference was a bit much initially. My 'secret' was to de-pressurize the tire by just pressing on 1 side (while deflating), in order to remove the inner tube by unseating just 1 bead. I removed the tube carefully, poured in 2.5 oz of sealant, and seated the tire with a compressor and a hollow Stan's valve no problem. Since then, the tire has held air like a champ with very minimal pressure loss.
The 29" 2.25 is really a 2.2 at any pressure under 30 psi (tubeless), but it makes for a sound, inexpensive rear tire. The knobs are well-pronounced and it rolls really well with minimal resistance. Not sure I'd put this on as a front tire but it's great as a rear and weighed 752g on a scale, brand new. I'm pretty satisfied, overall with this purchase but I wish CST would label this tire's width according to real-world specifications.
