Code R vs. RSC Levers
22K views 45 replies 23 participants last post by  SickEdit
#1 ·
Not terribly impressed with the power of my new Code R brakes, and read somewhere that simply swapping for RSC levers makes a big difference.
Anybody?
#5 ·
I'm swapping Rs for Ultimate Stealths today. As the link to the other discussion in the previous posts states, the upgrade is much more than contact point adjustment. I think the bearing in the lever and the sing link (more power) are the real standout benefits of the upgrade, but I'll see for myself soon enough!
#12 ·
There is absolutely a difference. I have a set of code r on one bike and rsc on the other. The r feel spongy and lack the bite the rsc have. If you swap the lever assembly the only real difference from a rsc set would be the piston material. It is worth the upgrade.
#16 ·
Codes (at least prior to the brand new ones I haven’t touched yet) are similar to TRP Quadiem in my reckoning. When they came out, they passed as an enduro/DH brake, but now have been left in the dust a bit as far as power goes, so are great for hardcore hardtails, trail bike, etc. I picked up a set of brand new Code R’s for a song, which will do just fine on the Japhy for now. When I find a good deal on some DHR-evos or similar, I’ll move the quadiems down to the Japhy, and pass the Codes down to someone in my family/friend group that needs an upgrade.
#31 ·
SRAM are working on a new DH brake so Codes should officialy go back to the trail/enduro category.
Code RSCs are pretty damn fine and they get excellent reviews.
The main issue over at SRAM is that their line up is not very consistent where lower end groupsets or brakes are low quality trash. Code Rs brakes specced all over the place are just a spongy mess.
Then you have Shimano where Deore brakes or groupset can pretty much get the same job done as XT/XTR with very simmilar feeling, just with more weight a little less durability.
#19 ·
Of course Code RSC are better than R and gives you more braking power, but they are still quite crap brakes.
There's so many new good brakes, that's why I don't recommenced just upgrade the levers.
Code's problem is you need more power to make them effective and if you ride a lot, you have to service the brake calibers often, especially the rear brake.
So for the same money you can get almost a new brake set, e.g. Hayes, TRP or Shimano XT 8120.
#26 ·
Thanks for all the replies. I'm an "all Shimano" brake guy, but would have had to wait two more weeks for the bike due to stocking issue, so thought I'd give SRAM another try, and have been a bit underwhelmed by the Code R.
Cambria has the RSC levers for a good price, so I may just give them a whirl:
Is this a damn good deal, or am I missing something?!
#40 ·
If you are reusing the same hose, there is no reason to swap olive/barb, just bleed. But you should not move olive/barb to a new hose.
To answer to the original question, i have both, r, rsc
The r are the worst brakes ever, their behavior is closer to an accelerator than to a brake. I tried everything, scientific bleeds, mtx pads, voodoo, rain dances, nothing.
Rsc are waaay better, still a crappy brake, but way better than the R, usable at least.
I just swapped both with hopes and I am a happy man now.
