Clicking from crank area under load.
52K views 10 replies 9 participants last post by  3fast3furious
#1 ·
Today I have notice a clicking noise from my crank area while pedaling under load. Doesn't matter which gear I'm in and only does it under load, for instance, the slightest climb, or when I was trying to troubleshoot, pedaling while using the brake on the road. If I just kinda cruise along and pedal, it doesn't do it. Just under any resistance. Does this indicate a problem with the bearings in my cranks? My next test is to swap the pedals out to rule them out or not.
Should it be bearings, etc., do I have to buy the whole crank assembly or are there replacement parts for the XT crankset?
#3 ·
There are somewhere around 13,987 differant causes for a clicking noise ...?
Yeah that number sounds about right +/- 2,000. The quick and easy looks are loose/cracked chainring bolts, suspension bolts, quick release, and cracks (frame, pedal, crank). After checking all bearings comes the greasing (bolts, derailleur hanger). Then comes the "i'll just live with it" . After a while rinse and repeat.
#6 ·
I cleaned the bike up from this weekend's ride, checked everything out, and swapped out the pedals. Performed the same tests riding on the road and using the brakes to apply resistance/load as well as climbing the one little grass hill here at my apartments and it seems as though the sound is not present now. I will leave these pedals on for the next real ride to know for sure. In the meantime, I guess I need to see about the XT pedals that appear to be the issue. Can they be serviced? Upon inspection, nothing seems loose. Checked the clips on my shoes as well and they seem fine. My guess is bearings in the pedals?
#8 ·
All the sounds and clicking problems I had over the years were all because of the BB or the loose crank bolts or pedals... So if you swap the pedals and it's fine, then you should have found the problem.
Good luck,
David
Sent from my iPhone while bikin'
#11 ·
Most higher end pedals can be rebuilt, although I have never tried with Shimanos. I just rebuilt my Time AttacXS pedals and it was relatively easy. But back to your original post (and I know that you determined it to be the pedals) no one had mentioned a very obvious possibility. When you get dust and dirt in the BB shell it will make that noise. It happens mostly when it is really dry and dusty. If you pull the BB and clean off the threads, then grease and install it fixes it. That just happened to me again this weekend. But since it was kind of wet during the race, the noise went away. So if your noise comes back when its drier, check that out too. It might save money vs. buying a new BB or something
