There are many reasons why brake pads and disc rotors rub. This issue is not just isolated to your Elixir CR.
What kind of front axle does your bike have? If it's a 9mm quick release, make a mark on the axle (not on the hub) so that the axle can always be installed back into the drop outs in the same orientation. There can be minute differences at the axle which will be multiplied by the distance the disc rotor is from the hub and cause rubbing. Once you've adjusted the calipers perfectly, you'll want to be able to return the axle to the same position every time.
Depending how much of a perfectionist you are, you can literally spend hours trying to perfectly center a set of calipers over the brake rotors. However, before doing so, make certain that the rest of the front end is optimal...
1. is your disc rotor true or is it slightly bent (uneven pressure at the disc bolts can cause the rotor to warp ever so slightly),
2. is your quick release properly tensioned so the front axle does not shift inside the drop out during a ride,
3. is your fork rigid enough to resist the torque exerted by your weight while riding
4. is the hub tension properly adjusted as a loose hub will shift ever so slightly on the axle and allow the disc rotors to rub,
5. is your brake over-filled and hence the pad to rotor distance is smaller than usual?
If all of the above are done, then spend time adjusting your caliper such that when the lever is pulled and the pads clamp down there is no movement of the rotor. I take the time to adjust my calipers so that the rotor does not move side-to-side at all and so that the pads are as perfectly parallel to the disc rotor as possible when viewed from the top-bottom axis and fore-aft axis.
Avid's method of loosening the caliper, then apply the brake, then tighten the caliper bolts works sometimes, but the result is usually not perfect. Take your time and have a drink (but not too many or the eyes might play tricks on you) while you work on this. I'm sure you'll get it perfect.
