Anyone using RF Aeffect Cranks?
17K views 41 replies 20 participants last post by  Ride_2_Fast
#1 ·
Shopping for a build and wondering if anyone is using the RF Aeffect crankset. It's looks like a great option, and pretty cheap for a direct mount crank. Can anyone share experiences?
#2 ·
I have some (not the fatbike version, but I can't imagine there's any difference but spindle length) and as far as I can tell, they're pretty much the same thing as the Turbines but with a 24mm steel axle (ie, Shimano HT2 style) instead of the 30mm aluminum one. So a few extra grams and in theory less stiff, though I'd be surprised if anyone can actually make any modern crank flex in any meaningful way.
IMO, pretty awesome cranks for the price.
-Walt
#5 ·
It's nice that RF now has some cranks with the CINCH spider interface, but not the 30mm CINCH spindle. Makes setup a little easier for folks who have a BB92 frame that's "supposed" to only accommodate a 24mm spindle. Though I do appreciate the innovation from companies who have made BB's that allow 30mm spindles to fit in BB92 frames.
#6 ·
Update: pulled the trigger of the aeffect crank, RF DH x-type bb and direct mount single ring. Whole setup looks pretty nice, only problem is when I installed it there was way too much space left between the BB and the crank. Called Race Face, got really awesome customer support. My BB shipped with only 1 spacer when it should have 3, 2mm spacers. 2 go on ds, 1 goes on nds.
Sharing here as you can't find this info anywhere because the crank is new and RF hasn't added tech specs to their website yet.
#10 ·
clearance for 104 mm BCD?
:madman: Ok, I have the Aeffect cinch crank, and I'm missing something here. I got a spider mount for it, as I'm going to use it for my commuter bike with a belt drive. The Gates 39 tooth 104 mm BCD chainring doesn't fit the 2X Race Face spider. See pictures below:
What's wrong? And how do I fix this, apart from taking one of the parts to a machine shop?
Could I put these shims (Race Face Chainring Shims > Components > Drivetrain > Chainring Bolts | Jenson USA) between the spider tabs and the chainring?
#13 ·
Its not a raceface problem, doubt you'll see that issue with normal chain rings. That shelf doesn't do anything anyway, the load is carried by the chain ring bolts. So either file the ring or dremel the spider. And it being off isn't odd at all. 1mm per arm is nothing being most rings dont even touch those ledges.
#17 ·
Yup, file or different cranks. Though you might just run into the same problem again.
Hopefully you checked to see if the sprocket would clear your frame!
Come to think of it, is this going on a fatbike? Because no way no how is a 44-45mm chainline belt going to let you run any fatbike tire I can think of.
-Walt
#18 ·
Yes, as far as I can tell, the Aeffect crank is for you if you have or need to use a 24mm bottombracket, but want a direct mount crank.
The direct mount cranks allow for wider chainline by using a 'flipped' chainring or a Boost chainring or spider.
This might allow you to run the narrower spindle crank(for 170 rear) on a bike with a 190 rear hub, getting better stance width while maintaining proper shifting and tire clearance.
All the other direct mount raceface cranks(Cinch) are 30mm spindle.
#19 ·
I run the RF Ride 170mm O.L.D. crankset on a Motobecane Night Train (197x12 rear end) frame.
The RF Ride 170mm O.L.D. Crankset has a q-factor of 202mm and clears my chainstays with plenty of room. My heels on my size 9.5 feet don't hit the chain or seat stays at all.
I run a RF NW 30T ring. To get proper chainline, I run the ring on the outer ring position (flipped). Chainline is within 1mm of a CINCH system running a 170mm o.l.d. crank with the "flipped" ring technique. And in fact puts it slightly towards the larger end of the cog, which is where I spend most of my time in the winter on my fat bike anyways.
So...the real benefit to the Aefect CINCH as far as I'm concerned is if you want direct mount so you can put on a ring smaller than 30T. If you plan on running a 30T or larger, I wouldn't choose a CINCH over the X-TYPE RF cranksets. I would buy whatever is cheapest that you like.
However, being able to run a ring smaller than 30T is a good thing as you can go 26/36 instead of 30/42, giving up very little climbing ratio and saving quite a bit of $$ on a 42T expander cog that I have, allows for better/quicker shifting, running a shorter cage derailleur, less chain, etc. And a little less weight.
Otherwise, there really is no benefit.
There are intangible benefits such as ability to move it to another bike by purchasing just another 24mm aefect cinch spindle. But at the price of the Aefect vs. a replacement spindle, you might as well just buy a 2nd crankset. It's not like the NEXT SL where a $80 spindle allows you to move your $450 crank to another bike.
#20 ·
@Walt
Yes, the chainline was the first issue I came up against. Originally I had bought the Alfine 11 hub for a Spot Honey Badger SS, but it didn't fit. So then I ordered this frame (Soma Fabrications - Juice Belt version):
And it looks like the Gates 39 tooth chainring will fit at a 44-45 mm chainline. And no it isn't a fatbike.
#21 ·
Then why are you posting about your application in the fatbike forum? This whole thread should really be in the Drivetrain forum, but it sorta makes sense here because the OP was specifically asking about fatbikes. Your application has nothing to do with fatbikes, so you had a lot of people confused.
#24 ·
Yup, light (630g 68/73mm with direct mount 30t oval from AB), well finished, all steel axle and bolt.
But one big disapointment, I use 170mm crank, mainly for added clearance, but 170mm aeffect are in fact 175mm crank drilled 5mm shorter...
Most cranks are that way. Way too costly to make a range of crank arms in 5mm increments. Especially when 5mm on the arms doesn't affect anything anyway, its not a performance matter nor any real life effect on anything else.
#30 ·
Which elastomer are you speaking of?...
On the RF *Ride* cranks (which at a headline level, at least, use the same system as the Aeffect) the "elastomer" (=squishy rubber washer!) is buried in the NDS crank, and you wouldn't notice it unless you dug it out. It's the fat rubber thing next to the crank arm here:
After it there is a black plastic shim washer, and the 10-11mm alloy spacer. There is a spacer and various black/red plastic washers on the DS too. but no squishy bit.
#34 ·
In this order, do the following.
1. Crack open a beer and take a sip.
2. Remove fixing bolt mounted on the drive side. It should take an 8m hex wrench. This is there to compress the two arms together and hold them snug. Standard threads.
3. Use isis drive adapted crank arm puller to remove drive side arm. Standard threading.
4. Tap out spindle and non drive side arm with rubber mallet.
5. Finish your beer.
