When you hear your frame creaking (and there are other things that can creak, its not always the frame). From what I've read over the years this is because the bores in the frame are oversized for the bearings. A machinist reference can tell you the exact range of desired interference fit for a pressed in bearing. I'm not sure on our small bearings how accurately you can measure this with a typical hardware store micrometer it might require a more preci$e tool to really know. (Note creaks can also be just because you didn't torque them down properly to so check that first).
Some bikes come with excessive tolerance and creak almost from day one. I remember I had a friend with a 1st gen Blur that did this and was eventually warranteed. If I remember correctly this was a common problem on that model.
In our case repeated pressing in/out bearings, or riding hard on them when they are not properly torqued will slowly open up these tolerances and after a few hard years the frame starts creaking. The usual solution to this is to buy a new bike.
There is the thought that you could put a high quality jb weld product in there and then machine it, but fixturing a bike frame properly for all the pivot holes and maintaining the required precision would probably cost more than a new frame. I was thinking more along the lines of some kind of loc tite product where a little heat could be used when its time to take the bearings back out, but I feel like the forces down there are just too strong for any kind of hardening product that would allow you to remove the bearing.
I also searched for oversize bearings - I 've seen that in the past where you could buy something +.001 or something but I didn't find anything, and with the precision of modern manufacturing I don't think you'd get very far trying to find something a little large out of spec even in a lot of 100 bearings.
do we really have to replace our frames or live with creaks because the bearing pockets are enlarged by .0001" ?
