Alt bars, who likes?
8.1K views 20 replies 9 participants last post by  Shark
#1 ·
Over the past year or so, it seems my arm/elbow pain had slowly been getting worse. Maybe it's just that I'm 40 now.
But my bikes are cushy (fatbikes and plus bike) both with suspension forks).
I'm going to try an alt bar for the first time. Ordered a Carver myti carbon. Should be here in a few days.
Anyone else using"crooked" handlebars and like or dislike?
Sent from my SM-G960U using Tapatalk
#5 ·
I tried Jones bars on a bike I borrowed. I thought they looked weird and would feel awkward, but I ended up really liking them. I have them on my fat bike now. The only problem I have is on tight, low speed turns. They bump my legs sooner than straight bars, so I have to plan a little more. Other than that they feel more comfortable and stable to me.
#8 ·
I have had a long history with alt bars and it all stemmed from riding singlespeed and rigid. I started with the Fleegle bars from On-One, which were ok but didn't have enough backsweep for me. I moved to the Mary bars also from On-one and felt like this was the sweet spot for me. I rode huge mileage on rigid 26" singlespeeds and then rigid 29" geared bikes all over Arizona, fast and rocky.
I could ride for hours on end and not have sore hands. Calluses and blisters would come and go but that was mostly the impact of riding with gloves in Arizona and twisting the bars for control on the rocky descents and ascents and sweaty hands.
I tried the salsa bar, can't recall what that was called, then bought a Jones bar with Jones Diamond bike and loved it even more. I rode Arizona for a couple of years on it and it never hindered me and I found my hands were more comfortable. Then I moved to Washington and found that I can use them just as well on skinnies, drops, and jump lines. Still like having them, just about out of my 40's and started using alt bars before I began this decade. If I moved to a full suspension bike, I might try a big wide bar but they feel weird to me now and I am not sure I could do it.
#10 ·
Got the new bars put on, slightly more narrow but close enough, quite an angle difference.
Going for an easy road ride around the lake this afternoon to see how they feel before hitting the trail.
Excited!
#11 ·
Yep. As others have written- they can be great.
I've used several what would be called mustache bars.
The more comfortable- the worse they are (for me anyway) when the riding gets super rough.
We run plenty of sweep on our touring bikes. Seating position is more upright. Neck feels better and I see more of the world passing around me.
Longer days? Great. I'm so much happier than w/ the standard drop bar set ups.
But hand numbness? I can't seem to get a grip on that w/ my riding.
I've had trips w/ long arduous days and the hands are fine. I've had smooth easy stuff and there's a dead finger or two for months.
Even when I think the terrain is forcing me to be more dynamic in my riding, i've had numbness issues. Thin gloves, padded gloves.
Lots of sweep. Less sweep. It still comes and goes. Mostly it goes. The issue isn't always there.
If you are riding lots of chunky spicy terrain, a bar w/ lots of sweep wouldn't be my first choice, or my first recommendation but there are plenty fast folks that say otherwise.
But- that straight broom stick that so many companies are making? It's no wonder that so many folks drive to the trailheads. I wouldn't want to ride their bikes very far either!
I'll be curious to hear what you think about them.
#13 ·
If elbow issues were the problem, swept bars are as good of a place to start as any.
Once you get the reach/tilt dialed, consider some sort of ergo/paddle grip. They allow you to more loosely rest your hands on the grips instead of having to have fingers wrapped and clenching. Relaxing your forearm muscles for a greater % of the ride is the goal.
#14 ·
I went with a SQLabs 12 degree handlebar. it has some upsweep and minimal rise. I tried going back to a conventional 9 degree low riser bar and it was a bit uncomfortable. I don't want to turn my bike into a beach cruiser, upright position, so 12 degrees and 760mm wide is just enough to make the position comfortable but I still feel in control. I tried 20/20 and a few other odd-shaped handlbars and this is the sweet spot for now.
