Hi Guys,
I have a 2017 Top Fuel 9.8 with less than 100 miles on it, and it appears the rear shock (Fox Re:aktiv XC) has developed or has always had a clunking feel / knocking sound.
The best way to describe it would be a feedback that I can feel through the pedals, like something in the rear end is loose. Most noticeable going through small bumps in rapid succession, inducing a lot of chatter in the rear end. I can duplicate the knock just sitting still on the bike and bouncing on the pedals. I can feel the clunk during initial compression, and again when it rebounds, almost as if there is a worn out shock bushing. Doesn't matter which position the remote lockout is in.
I've ruled out loose cables, seat post, pivot bolts/nuts, wheels, bottom bracket, and headset. There is no slop in the rear triangle when trying to deflect the wheel laterally. The suspension seems to be working normally, but I am still fairly certain it is the shock.
Has anyone else had a similar issue with there Re:aktiv XC suspension?
Planning to take it in to the LBS, just concerned as I have read some stories of older models with the Re:aktiv shock having similar issues that went ultimately unresolved or were considered normal. Talking to them on the phone they hadn't had any experience of the sort on this model, evidently.
