I have bought a 197 frame and I already had the 190 hubs. It can be done with spacers as mentioned by Jay_RigidRide. Just make sure the axle that came with the wheel is actually long enough - mine isn't or I could have also used spacers.
That didn't bother me because I had bought the wheels just for the rims, but that's when I discovered the next snag.
I bought a set
Hope FatSno hubs (197mm and 135mm) to build up the wheels. I thought they would have come with axles, my fault, I should have checked.
They took 4 weeks to arrive, probably because my lbs didn't get round to ordering them even though they knew I was wanting them for the WEMBO World Championship 24 Hour Solos.
So anyhow, I got them with a week to go, discovered the lack of axles, and back to the lbs to urgently order them. (No problem with the front, the existing axle was ok).
And this is where the snag came up.
Hope make 197mm hubs, but don't make 197mm axles! They were adamant that the axle should come with the frame because at that size they screw in to the frame. I explained, no, it is actually a through axle and is fastened with a nut.
So there we have it, if you are buying a
Hope FatSno to build a wheel, don't assume axles are available if you have an actual through axle frame rather than one where the axle screws into the frame.
So my ultra light weight weenie carbon fat fantastic was sitting all ready for WEMBO, but lacking a back axle and not enough time to source one.
I rode my
29er in the race and now have a very shiny 197mm desk ornament.
