I helped design a new trail system in 2003. We used pink pin flags and flagging tape of three different colors.
I spent this past weekend "tight flagging" the last 2 of 6 loops we will build this fall. It has taken these years to get the NEPA done, the grants written and to build the first 4 loops.
If your flags are going to be in the woods for a long time try to use pin flags. They don't fade as bad as flagging tape and are in a predictable postion - 2 feet off the ground or lower every time.
If you have to use flagging tape, I'd use orange. Orange is the best combo of short and long term use. Orange can be seen well and doesn't fade to a color that is really hard to see. Red isn't the best for the short term, but it fades to pink and can be seen pretty good after 4 years in the field. Pink is great for the short term, but fades to white and is really hard to see after 4 years in the field.
