Yari vs Lyrik Ultimate with dampers fully open
6.3K views 16 replies 13 participants last post by  FactoryMatt
#1 ·
Hello, MTBR hive mind! I've seen many comparisons between Yaris and Lyriks. I understand that the difference mainly comes down to the dampers (MoCo for Yari, Charger for Lyrik). The thing I have never seen anyone discuss is whether there is much of a difference between the budget MoCo damper and the premium Charger damper if both dampers are fully open. In other words, does damper quality matter if the damper is fully open so the oil is flowing freely?
#7 · (Edited)
Even fully open the Motion Control damper on the Yari has a limited oil flow capacity (compared to a damper with a shim stack for example)*. The MoCo allows oil to flow through some holes, where adding compression just makes the holes smaller. The diameter of said holes in the open setting can only allow so much oil to move back and forth in successive hits, so if you bump into obstacles at a certain (high) speed/frequency the fork will effectively get "locked out" after the first few hits.
I used to own a Yari and tried everything apart from changing the damper. My best result was replacing the oil with a ligher viscocity one, removing all tokens and adding about 10-15 more PSI than recommended. This helped the fork stay higher in it's travel where it's more supple and moves more freely overall. Still it wasn't enough for out rocky terrain so I ended up replacing the fork with a DVO Diamond.
So yes, even fully open a basic vs a more sophisticated damper will ride very differently.
*Feel free to correct me if I'm wrong on how dampers work
#9 ·
Yari can be modified to work better by shiming the pippet to have it opening sooner, and if you are up for some dremel action you can shim it which makes it work just fine. But some work and experimenting is needed to make it work, if just want to instal your fork and ride Lyrik is the better option.
#12 ·
I can only do one scoop rice. Two scoop rice makes me feel like I'm going to explode
  • Haha
Reactions: Nat
#17 ·
shameless plug, i have a Dougal-tuned (Shockcraft) "Unharsh" Charger damper for sale here: (i moved down to a Pike and had him mod another one for me).
