on a previous post i was told these were terrible.
why is that? and also, are they air or oil?
thanks
thanks
They are coil/oil forks.congonic said:on a previous post i was told these were terrible.
thanks
binary visions said:They are coil/oil forks.
The reason they are "bad" (though this is a relative term) is that they use a simple ported damper in the fork to control oil flow. That means that the way they restrict the oil flow in the fork (in order to keep it from compressing too fast) is by forcing it through a small hole. That works well for low speed compressions (drops, slower speed hits, etc.), but when the fork tries to force a large amount of oil through, it can't and locks the fork out.
But keep in mind that you're talking to a bunch of bike snobs here. It's not a bad fork. It's simply a budget fork, and performs as such. It's not nearly as good as a good cartridge damper fork like a Super T, Shiver, 888, Sherman Slider, etc., but all of those forks cost twice as much so you'd expect more performance out of them.
slow speed impacts, which are generally things like drops and jumps, hence why the same damping mechanism isi used for the dirtjumper forksnoonan28105 said:So .....What is this fork good for then? Is it good for aggressive budget trail riding, few drops less then 8 foot. what is it good for then.
Jm. said:and lots of people drive fiats too...
my mistake was buying a Jr T after having a Z2 and an Xvert...
my main beef with them is that at a certain speed, they just dont work. I'd rather a budget fork be ok all around, rather than good at low speed and terrible at high speed, either that or some sort of non-adjustable cartridge that you have to put different oil in to get a different feeling (like with the old manitou mach-5 pro-C forks)...
The Drop Off Triple is a 6", double crown fork, so it's not the same travel or quite the same chassis.Jm. said:yes, same chassi, same travel, but it's very much NOT the same fork, the Z1 will be plush and active in all conditions in a very wide speed range, to adjust for bottom you'll raise the oil level as with any marzocchi (if say you are going to use it to dirt jump or whatever), the cartridge dampers in the Z1 are just worlds better than the ported damper in the dropoffs. If you have to ride on a trail to get to dirt jumps, you'll appreciate the Z1, in fact in pretty much all conditions you'll appreciate it...
try reading the preceeding post next timebinary visions said:The Drop Off Triple is a 6", double crown fork, so it's not the same travel or quite the same chassis.
Other than that, I agree with this post- the Z.1 will be a much better damper.. again, if it falls within your budget.
Jm. said:try reading the preceeding post next time
He was talking about a dirtjumper vs a dropoff vs a Z1.
is this for real? because if it is, you need to be dissallowed from posting anything at all....oreo321321 said:I havent read the posts in this thread, but I have the 2004 stinky with the drop off triple. I love the fork. It has like no sag, and is EXTREMLY ajustable. I mean from like bottoming out off a curb, to a rigid. I dont care that it is not that great for slow small bumps (like Really small bumps) but who rides slow anyway? Its very nice. I jumped a blind hill into a parking lot (stupid of me), and so after I landed I realized there was a parking block at the bottom, i had to run right thorugh it very fast, it soaked it up very nice. If this is your first big travel fork, or dual crown, it's great, and EXTREMY AJUSTABLE.
And if the first fork over 3" that you ever have is a Jr T, you should be barred from reviewing the fork untill you've owned something different.zedro said:is this for real? because if it is, you need to be dissallowed from posting anything at all....
i think there should be a rule that you have to have experience on more than one product before actually giving a review of it...![]()
I kind of want to dissect all the things that are wrong with that post, but I guess I shouldn't completely crush the kid's spirit...zedro said:is this for real? because if it is, you need to be dissallowed from posting anything at all....
