Thanks, that's helpful. So as an example, if I look at the yellow line at 8 on the Y axis, and follow it over to 6 on the X axis, the combined angle is about 10 degrees. Makes me wonder if its worth pursuing 12/0 bars . . . not that Syntace quality isn't desirable regardless.
Thats right. The combination is Pythagorean.
I dont think its sensible to spend money until you know the bar angles you want, and for that you just need to feel it.
i was iterating on used bars, playing with stem lengths, was slow going and i kept going back to some shorter bars because they had a nice give. Surprising how much bar stiffness can vary. Some longer bars are toxically stiff.
Luckily i bought a used bike with 780 enve m6, much more sweep and i feel theyre perfect for me (after i installed a shorter stem.) theyre specced at 9 degrees and 5 degrees, which from above chart is a bit over 10 degrees.
i sold that bike and missed those bars.
i dont like fancy marketed brands like enve but in this case ive been really happy to pay their premium (still bought used.)
i dont believe in description with separate ‘backsweep’ and ‘upsweep’, is confusing explanation. there is just sweep and rotation (and then bar hand offset from stem). Bars are a difficult thing to describe, general spec needs linear algebra to interpret so best to fit in person until you know what you like.
I orient my bars to have a slight upsweep, makes my hands and wrists happy for where the stem puts them.
