Got my pennies saved for the 2018 White Argus Comp and It's nowhere to be purchased.
What's the deal with these new bikes?
Did you call Mongoose and what did they say? I would also complain about that scratched rim.Ya the rim came with about a 13 mm gouge scratch. Other than that it was fairly flawless and it was packed pretty well.
On my last ride this past Friday the front brake was humming pretty bad went to go adjust the caliper bracket and the bolt just kept spinning. I kept it as is and kept writing but haven't messed with it since. I am going to contact Mongoose to see what they could do about it because it seems stripped out which is a pretty big bummer for only a few rides in.
Any update on this?You know I didn't complain about the scratched rim but I think I will bring that up. I have an open ticket with them or I just sent them pictures. We'll see what happens
Mongoose offered me a Blue Fork from last year's model and say there is no ETA on when they can get a black one. they also said I can try and return it through Amazon but that is out of the question for me so I asked them for more options.Any update on this?
If the issue was the rim alone then yes I would *maybe* pass on getting them involved. But remember contacting them originated from the randomly stripped post mounts that happened on one of my first rides. There were even other nicks, dings and scratches (from shipping I assume.?)once I received the bike. so far I have only added the rim (largest issue of the shipping damages) to the stripped post mount ticket. We'll see.A scratched rim?* Is it really worth the headache to process a claim?* Take a black Sharpie to it and go ride.
Not the OP but I can help! ?OP
I was curious; did you have a chance to weigh the argus comp?
Ok wow. The Argus is pretty comparable to other fatbikes then.My aluminum frame, extra large, Salsa Mukluk is 32#, tubeless, with pedals.* 33# sounds very good.
rotational mass is where weight savings mean the most.Ok wow. The Argus is pretty comparable to other fatbikes then.
I'm not really sold on tubeless yet but not necessarily opposed either. I'm used to riding with two spares but I'm only riding with one spare currently because I can only fit one. The one I carry is heavy too.
Also note that I also ride with spare "tire rubber" (cut up pieces of inner tube), sandpaper and adhesive for for flat repair.
My question is what would I need with me to switch to tubeless? I get it, I would have 3 less tubes then currently but I figure I would still need repair Kit I currently use and maybe even more parts that go with a tubeless set up..?
What do you think?
Most tires can be run tubeless. Many find that Zip or Tyvek flashing tape works better than Gorilla tape. The biggest challenge is the rim. I am not familiar with the Xposure rims to know if they will hold tubeless at low pressures.rotational mass is where weight savings mean the most.
to go tubeless you need:
gorilla tape, a tubeless valve, sealant (home brew works great), and tubeless tires.
Did you have nicks, dings and scratches to the actual frame and fork right out of the box?Mongoose offered me a Blue Fork from last year's model and say there is no ETA on when they can get a black one. they also said I can try and return it through Amazon but that is out of the question for me so I asked them for more options.
Sheeit, that's it? What kinda rides do you do with that?I carry a couple CO2s and a cell phone.![]()
So what do you do for rips? Walk it back?One would have a hard time breaking a bead loose, patching a hole and reinflating tubeless on the trail.
You got a point but that still seems like quite the risk don't you think? These fat inner tubes blew my mind how big they are. Not to mention super heavy too (compared to standard or 26x2.5)A 26 x 2.75" MTB tube will stretch and fit a 4" tire. They are much lighter.
Yup that's right! I believe it. I read similar stories about the Mongoose/Amazon bikes.. Doesn't make em bad bikes just means they need to invest more in packaging..Did you have nicks, dings and scratches to the actual frame and fork right out of the box?
The blue Comp that I purchased last year had a real bad scratched fork and several dings to the frame itself.
is this just for day rides? That is almost as much as I take on 2-3 day bike packing trips. That seems to be a lot of extra poundage for the regular 2-3 hour daily trips, unless you are a trail steward, or are in training for bike packing...Sheeit, that's it? What kinda rides do you do with that?
Heres my list 😲
Frame bag contents: 2L water bladder, water bladder hose, water bladder hose insulator, 1 fat inner tube, 8 extra zip ties, 2 pair of socks (1 for cell phone, 1 for me), Neosporin, gauze, injury/hospital tape, chain lube, tire hand pump, locktight, inner tube pieces for flats, small scissors, rubber cement, sand paper, 3 folded paper towels, spare master link, spare chainring bolts, sun glasses, goggles (I wear one or the other)
Total frame bag weight - 9lbs
Seat bag contents: Allen wrench set, 15mm(?) pedal wrench, needle nose pliars, full can of aerosol bug spray, small cloth rag, master link breaker tool, full finger gloves, half finger gloves (I wear one or the other)
Total seat bag weight - 3lbs
Both bags total - 12lbs (yikes!)
Ya I'm a packrat when it comes to mountain biking but a minimalist for the rest of my life.is this just for day rides? That is almost as much as I take on 2-3 day bike packing trips. That seems to be a lot of extra poundage for the regular 2-3 hour daily trips, unless you are a trail steward, or are in training for bike packing...
not hatin' - just being curious
Use 5" stretch wrap instead of Gorilla tape. Easier and lighter. If you have 80mm or less width rims, you don't need to overlap from side to side. A single pass 5 times centered works.to go tubeless you need:
