Well, after giving up on the old Charger 1 that came with my Pike, I decided upgrade to the Charger 2.1 RCT3. The only one that fits my 2016 Pike.
It worked fine for about 2 months, in the sense that it had a wider range of adjustments than the Charger 1 and it did not seem to"stiffen up" after every week or so of riding.
But little by little I had to decrease the slow speed compression, and finally yesterday I was back to a fork that simply ignores small rocks or roots or ripples on the trail: you feel every single one of those ... straight in your hands :madman: and this with a ACS3.
I opened the bottom to "air out" the damper leg, like it did with the Charger 1, and it seemed to help, so there might be some air build up. But the amount of stiction that is present if I put more than 1 or 2 clicks of slow speed compression is outstanding.
What's wrong with this crap? Do I need to change the fork seals (already?). Should I just toss this junk in the garbage and get a different fork (but which one ... not RS or Fox ...)
