Buying a new set of hoops and the ERD is about 5mm off. Going from older flow ex to new Mk3 Flows. Do I need to be worried?
? I didn't see any conflicting advice. If you want to re-use the spokes you'll need a rim with the same ERD (or very close) as your old one. 5mm is way too far off and will require buying new spokes.Lots of conflicting messages here.
Right what he said. meltingfeather was clear in his statement that the old spokes should not be reused. They will either be too short or too long based on whether the erd of the new rims is more or less than the old.? I didn't see any conflicting advice. If you want to re-use the spokes you'll need a rim with the same ERD (or very close) as your old one. 5mm is way too far off and will require buying new spokes.
If the ERD of the old rim and the new rim are near identical you should be ok. The 5mm OSB shouldn't cause an issue. I just built a new wheel with an i9 classic and a 5mm OSB. The calculations between the symmetrical wheel and the asymmetrical wheel were like .7mm. After building 6 wheels now I don't think .7mm is enough to make new spokes worth it.Lots of conflicting messages here. I want to use the spokes already on the wheel as replacing 64 Industry 9 spokes can be a costly endeavor. The only reason I am replacing the hoops is because they are old and my wife's punched a hole through one of the wheels on a rock. So Melting feather, I should be able to use the spokes, no?
ERD stands for erroneous rim diameter. Because whats stated on the rim and the makers site is wrong.Buying a new set of hoops and the ERD is about 5mm off. Going from older flow ex to new Mk3 Flows. Do I need to be worried?
1. I9 wheels do not have nipples.Well, just to throw a spokewrench in the works, we also need to know if the new ERD is larger than the old ERD, and we need to know what size spoke nipples you currently have.
A quick google shows that the new ERD is 5mm *bigger* than your old rims, so you may be able to get away with running a 2mm longer spoke nipple, and keep the same spokes. This is assuming that you used 12mm nipples on the old setup. Id be a little leary of jumping from 14mm to 16mm, but in a pinch, it should do.
But really, new spokes are the *right* way of doing it. Running longer nipples are a cheat/hack/shortcut and will likely cause your rim to explode, instantly killing you and everyone you happen to be riding with. You have been warned.
How'd you know?Erect Reindeer Dong.
Aren't these stans rims? I didn't catch what hub or spokes he used.1. I9 wheels do not have nipples.
2. Longer nipples would only work if the nipples have longer threaded length. Not all do.
That is the method used in the late 1800's to accurately measure wheel diameter. It has since been phased out as peta grew stronger and more advanced.How'd you know?
You need to pick up in this dude as the stated ERD is usually incorrect. Before you go any further you really need to actually measure the ERD so you know what it actually is. Which might just save you buying the wrong spokes!ERD stands for erroneous rim diameter. Because whats stated on the rim and the makers site is wrong.
