Which brand are most of the components on your drive train from?
But luv when's.I pretty much mirror edub ^^ with SRAM shifters being a better feel with the positive click.
SRAM XO trigger shifters.
SRAM XO rear der.
XT front der.
XTR crankset.
XTR cassette.
XTR chain
Hope breaks![]()
Really? Often?Hope breaks![]()
This one's better.But luv when's.
They both make great products. Just a word of advice to the OP. Whatever you go with be sure to stay with the same brand with the front rings and cassette. They are meant to mesh together and the shifting will be much smoother using the same brand on both.All Shimano now.
I used to have a mix.
What? I have a race face front ring and XT cassette on one bike and xx1 front ting on the other. Shifting is great.They both make great products. Just a word of advice to the OP. Whatever you go with be sure to stay with the same brand with the front rings and cassette. They are meant to mesh together and the shifting will be much smoother using the same brand on both.
+1. Some people might prefer the ergonomics of one over the other, or else sound / tactile feel, but I've never found I had any issues switching back and forth given an open mind and a few minutes to acclimatize. In terms of performance they both work great if set up and adjusted properly.They both make great products.
Mechanically I'm really struggling to figure out why this would be the case. Sounds like you've bought into what the respective companies are feeding you. If we really split hairs I guess I can see how chamfering of chain side plates might be optimized to the profiles of the teeth on the rings and cogs as the manufacturers might claim, albeit in some miniscule fashion that is probably the least of factors that will affect performance in real-world use, but rings to cassette? Sorry, I can't put any credence in that unless you also are also willing to swallow the bit about the chains too and have a complete match across all 3 of cassette, chain, and rings.Just a word of advice to the OP. Whatever you go with be sure to stay with the same brand with the front rings and cassette. They are meant to mesh together and the shifting will be much smoother using the same brand on both.
They do both make great products. I actually really liked the X9 triggers I used to have. The shifting was very nice. I wish the upshift lever was movable on X9 like it is on X0, but otherwise, it was sweet. ditto for satisfaction the X7 RD. the Tension spring was so good I actually ran it 1x with a N/W front for several rides with no chain drops.They both make great products. Just a word of advice to the OP. Whatever you go with be sure to stay with the same brand with the front rings and cassette. They are meant to mesh together and the shifting will be much smoother using the same brand on both.
I knew my advice about running the same manufacturer with rings cassette and chain would bring flack. But in my opinion all 3 are designed together and to work together. If you scroll up toMechanically I'm really struggling to figure out why this would be the case. Sounds like you've bought into what the respective companies are feeding you. If we really split hairs I guess I can see how chamfering of chain side plates might be optimized to the profiles of the teeth on the rings and cogs as the manufacturers might claim, albeit in some miniscule fashion that
??100% SRAM-Love my XO grip shifts. Buy American.
