So, I went to air up my tires today to ride and the nut on one of the presta valve cores was stuck, which has been a sort of recurrent problem for me with these stems/cores, filling sealant through the stem. So, I pulled it, wd40d it and rinsed under hot water and wiped off. Everything with it seemed fine.
When I went to put the core back in, using one of those tiny wrenches, I did kind of torque it and thought I felt the stem turn maybe a little. But, I wiggled it, tightened the nut a little bit and everything seemed fine and solid.
Tire was flat when I got to the trail. Eff me in the a.
Went home, aired it back up, listened for hisses, checked the bead, everything seems ok. Checked it a few minutes later, still holding air. Few hours later, flat.
So, the obvious solution is that the core is jacked somehow, or maybe I jacked the actual stem with that "overtorquing"? I had a few cores lying around, but can't find them at the moment or I would test that out.
It is time to refresh the sealant, but I don't know the condition/haven't looked. I have sealant on order, but it's coming slow boat apparently. It occurred to me that I might have twisted the stem, "broken the seal" and don't have enough sealant to properly get it sealed back up.
Any other problems I might be missing?
