So I have a Hightower LT w/ a Fox 36. It came with Guide R and 180mm centerline rotors F/R. The calipers bolt directly to the frame and fork (just a bolt and a flat washer). I ordered 200mm centerline rotors for the front and rear and the adapters from my LBS. I was expecting the bracket style adapter that spans between each bolt but instead got separate spacers for each bolt with a bunch of conical washers. I haven't seen this type of adapter before. The spacers with conical washers on each side cause the caliper to tilt and I haven't been able to get rid of the rotor rub. The setup seems pretty janky.
I've seen videos of the bracket style adapter being mounted on a 2018 Fox 36 so it seems like either can be used. What's the difference? I'm not sure if I should keep the spacers and try to make it work or order the brackets.
