I think it looks like an Ibis but pinkbikers are already on the attack
I think it really depends on terrain. My Chisel has a very similar BB drop/height (63mm drop / 309mm height vs 65/308 on the DV9) and i've never hit anything with my cranks. I'd honestly only be worried if this was a FS bike we were talking about.If the BB is that low, it's a definite no. I've had friends crash from catching small stumps in races. I've seen hospital trips due to the bb being too low. I've broken countless crank brothers pedals and the bb has only gotten lower in the last decade.
Had no issues. It was setup with a 120mm fork and the old one was designed for 100-120mm. Also, it was a Fox 34 Rhythm, so ran about 15% sag. Finally, always ran it with 2.6 tires. So in combo, I may have been riding with a dynamic bottom bracket height 10-15mm over someone running a 100mm fork and 2.3 tires.So that bike had published 300mm (11.8) BB height before your angleset. How'd that work out? I think you're the only one here with experience on the old model.
Using a 29 wheel with 740mm OD, gives 370 axle - 65mm drop = 305mm actual height on the new DV9. Someone can correct my math but I think the old one had roughly same BB height.
Best friend was on a 307mm and ended up with broken ribs. The trail builder left a tiny stump and his pedal caught it during a race.I think it really depends on terrain. My Chisel has a very similar BB drop/height (63mm drop / 309mm height vs 65/308 on the DV9) and i've never hit anything with my cranks. I'd honestly only be worried if this was a FS bike we were talking about.
Pinkbike is indeed a bit of a disgrace. It is basically a repository for industry press releases, and the comment section is left out of control resulting is a twitting venting machine.I read the PB comments and am pretty much embarrassed to be associated with the MTB community if this what most are really like. Just dozens upon dozens of posts with vitriol and hate and insults because....the top tube isn't straight??? Good lord, man. Pathetic.
does 5mm really make a noticeable difference in rock strikes?I’m 6’1 and switched to 170 cranks to reduce rock strikes on modern geometry bikes after for years swearing by long cranks.
I had the same doubt, but then I tried it and I have not had as many. I also ride like an old-school trials rider at times, so I got that going for me.does 5mm really make a noticeable difference in rock strikes?
That depends on the rocks. 2mm could make a difference.does 5mm really make a noticeable difference in rock strikes?
Yes.does 5mm really make a noticeable difference in rock strikes?
Probably the same marketing majors at Ibis who called an XC hardtail do-all.When the guys who didn’t get in their first choice of college and majored in marketing then start talking $#!+ about frame geometry…,
Absolutely. Same. There is no reason to ship a Full suspension bike with 175mm cranks, it's just dumb.Yes.
Moving from 175's to 170's on my Ripley eliminated nearly all rock strikes.
When I moved to my SJ Evo, 170's were rock striking like crazy when I tried to pedal like I was still riding my Ripley. Moved to 165's and issue solved.
I saw the IS in the spec but didn't know what the old frame was... I'll pay shipping for your old, obsolete CKlucky enough to get my greasy hands on a new DV9 frame.
