Hi,
Just got this opinion from the designer at Pole.
Anyone experienced want to comment, seems false to me, hence my checking?
"Personally, I don't see any reasonable point on the coil in forks. The air spring offers a nice ramp up and you can get the spring rate spot on. With coil, you are most likely to have more harsh bottom outs than on air-sprung. There is no fork or shock that will give you the plushest ride ever (similar to moto) because there is no mass on the bike itself that will load the suspension. The SAG is made only by the rider. The only way to make the bike less harsh is to use heavier stuff (tires, wheels, etc.). This is one reason why all Pro's run air springs and DH tires at EWS.
But... you won't know if you don't try it. I say go for it
That's how I learn stuff as well.
ires (and inserts)are an essential part of the suspension as they damp the ride in the first part of the stroke. The excessive talk about unsprung mass -talk has gone too far and it is actually working counter benefits of the riders. Strong wheels, thick sidewalls, and inserts will make your ride immediately better.
The "unsprung mass" that you don't feel when you take off the chain and derailleur is actually the lack of movement of the chain and the derailleur that is slapping around. The chain is heavy and the movement of it with the derailleur is causing the feeling of "massive unsprung mass".
I have ridden light and heavy bikes and the unsprung mass is not the problem. The biggest problem in most cases is too nimble products and a lack of understanding of how suspension works. The bikes that have the most horrible suspension setups have too low tire pressure with light tires, suspension setup way out of the factory standards, light wheels, weird cockpit setup that puts your weight off the ideal, and imbalance of the rear and front springs.
From my understanding, for the most effective suspension, you want the heaviest frame and lightest wheels going. You want the frame to functionally stay still while the wheel moves over the obstacle.
Obviously there are other benefits that increase weight, but it's not the increase of weight you want. I run DHR tyres for a ton of benefits, but if they could be magically half the weight it'd be better for suspension?
