1 - 10 of 10 Posts
c0jones
· Derailleurs owned: 0
Discussion starter · #1 ·
The only original parts are: rear hub/sprocket/shifter, pedals, chain and seatpost clamp.
Frame: 2003 Trek Clyde 20" (half of kickstand bracket cut off)
Fork: 2002-03 Bianchi D.I.S.S. (uncut)
Headset: Cane Creek S-2, 1 1/8" threadless
Handlebar: Easton EA70 Riser bar
Stem: Nashbar, 90mm 40Âş
Front Brake: Avid mechanical disc 160mm
Front Lever: Avid AD-3
Crankset: TruVativ ISIS drive Stylo Team 180mm, 32T, with CNC rock guard
Bottom Bracket: TruVativ ISIS SL 113mm, cartridge
Chain: KMC BMX 1/8"
Sprocket: 20T
Pedals: Wellgo
Rear hub: Nexus 7-speed, w/ coaster brake 36 hole
Front hub: XT M756 disc 32 hole
Rims: Alex TD-17 disc
Spokes/nipples: Wheelsmith, black 14 gauge
Tires: WTB, front Kevlar Nano Raptor 29x2.1, rear Mutano Raptor 700x44
Shifters: Nexus twist
Saddle: Trek, from Navigator?
Seatpost: from Bianchi Milano 27.2mm
Grips: Salsa Pepperjack
Bar ends: Singletrack Solutions
SHWEET!!! I love the frankenbikes (Stein, not Al)
That looks awesome. How is the clearance in the rear? How about the handling with that nutty head angle? Great job, I really appreciate your post.
-Sean
P.S. Check out my funky Manitou HT cyclocross conversion in the singlespeed forum
Discussion starter · #4 ·
I cut off half of the kickstand bracket... now I can remove or install Mutano 44 without deflating.
Now I might be able to fit a 29x2.1 Nano... but would have the install/remove problem again.
Handling is not nimble... but,
What if I put a road fork on it with road tires and a fixed hub?
-Sean
Interesting!
I have one of those in the garage. It's a 2001 I believe, v-brakes front and rear, 4 speed Nexus (no coaster brake), a rigid fork and in it's stock form with <gasp> 26" tires. It's sort of a tank and pretty much a cruiser bike. Sounds like you've dropped a couple of bucks on it to try and change that! I suppose you've run into the same problems that everyone has when trying to convert a frame from 26 to 29.
What are you riding it on and how does it ride?
Try lowering the stem...
It looks as if you've got a riser bar in addition to a really high stem. If you put on a negative rise stem, that should tighten up the handling quite a bit.
Sean
Discussion starter · #7 ·
I think the earlier Clydes had a steeper head tube angle, and might not have as enough space for big wheels/tires. Mine had extra room for fenders. I didn't have the usual 26->29 problem of brake posts being in the wrong place... there are none. Yes, I wasted more money than I want to add up... My original reason was to get more ground clearance... Works well on mild trails, not so great on tight corners.
TeamSwami.com said:
Interesting!
Discussion starter · #8 ·
It would still have a ~69 degree headtube and long wheelbase. I'll probably leave it as is for a while... I have a pair of singlespeeds that handle quite well.
Sean
I like it.
That is a cool bike. I wouldn't mind having one of those. Have fun with it.
I did this, too. . .
I have an older incarnation of the Clyde that has been different things at differnt times. I converted to 700c, but not true 29." I was running 700x42 Panaracer Mythos CX's. I ran a fixed gear in back so that I could skip the rear brake, and I found that on old long-reach Diacompe centerpull brake worked perfectly with the 700c wheel and the stock fork. It was a fun set up. The BB is so riduclously low on the Clydes that putting the bigger wheels on it actually took it into the normal range.
Have fun with it!
1 - 10 of 10 Posts
You have insufficient privileges to reply here.
