I'm pretty sure my tire gauge is entirely inaccurate now for some reason (cheap Zefal model), and I wouldn't mind spending some money on one that actually works well. Any ideas?
I bought the standard 0-160 psi for my roadbike and then special ordered a 0-60 psi gauge for my mountainbike. Instead of guessing somewhere between 20 and 30 lbs, I can read exactly 22 lbs for my front and 26 lbs for the rear tire. Cool thing is, special orders consist of no more than adding a note in the comments section explaining what you want. Costs the same as the standard item, which is still less than pretty much any of the cheap presta valve gauges sold by most bicycle accessory companies.tedsti said:http://www.getagauge.com/BicycleTireGauges.cfm
These are nice. They will even put on a 0-60 psi dial so you have more resolution if you don't need the higher pressure readings for a road bike or the like. I had a 0-30 psi made for my pug tires.
