The single consolidated official drop bar thread
1 reading
325K views 719 replies 171 participants last post by  CSIPSD
#1 · (Edited)
Edited for clarity, I hope
There are some drop bar bikes that are set up really well and some that aren't. I'm hoping the ones that are set up really well predominate in this thread. I see some bikes posted in other forums that are really bad and it would be nice for folks to be able to find properly set up drop bar bikes in one place as a reference of sorts. VRCers seem to have the hang of setting up dirt drops. I know there are a few styles of offroad drop bars, and people have different preferences, but generally proper dirt drop bar setup fall in a pretty narrow range.
Enough people ask about this topic in this forum, and you see plenty of people using drops these days on new bikes, how about nice repository for properly set up bikes, vintage or otherwise, with drop bars. Let's include links to external resources like Shiggy's and Guitar Ted's, good photos of 'proper' setup, philosophy, anything that will help the newb when they decide to try drop bars offroad.
http://mtbtires.com/site2/features/37-bikes/85-why-i-ride-dropbars
http://g-tedproductions.blogspot.com/2008/10/drop-bar-for-mountain-biking-part-i.html
#698 ·
Nitto 100mm dirt drop stem, origin8 gary bars, and tektro levers with crosstop levers. All been used once and sitting in the shop from my failed dirt drop attempt 5+ years ago. The handlebars will be trickier to ship but everything else will fit in a medium flat rate box. P.M. me if interested. I'll get them on the classifieds as well.
#700 ·
Has anyone converted to drop bar and kept original hydraulic disc brakes? this is a big issue for me since i need that stopping power from my reliable shimano deore disc brakes.
I have a 1x9 shifting now since I just dropped the front derailleur.
#704 ·
With hydraulic road brakes becoming a thing - it could be done. No hydraulic road levers come in 9 speed to my knowledge so you'd be looking at 11sp which means new everything else. Dollars add up big time there.
I have had good luck with the Avid mechanical road disc callipers which work specifically with the pull of road brake levers. I have heard good things about TRP mechanical callipers too.
I doubt you could run MTB brake levers on the flat of the bar due to clamp/bar diameter compatibility and even if you could it would be a bit goofy and a bit unsafe if you spend any time in the drops.
Grumps
#710 ·
Nishiki I saw sitting in the trash. Converted to 44/18 single speed, bars were left over from previous. All in, less than $200.00 Quirky geometry, but very quick. Oddest feature has to be the chainstay mounted rear brake.
Compliments on this build, much improved over the before photo. Nice reuse of matching stem for the win.
/also super sleek saddle on $5 post
#711 ·
1939975
1939976
Dubbed Project Zero... initially a parts bin build.
My dad bought this GT Timberline back in 93. Sat for nearly 25 years, so I blew it apart, sanded down, repainted, and pieced together with various parts as a kart road/gravel cruiser for my local neighborhood.
#716 ·
Here is one of my favorite bikes. A 1991 Bridgestone MB-5 set up with dirt drops. Super cruisey -it’s surprisingly fast on the road, and amazing on forestry roads here in the Canadian Rockies. Paul brakes, Trp levers, specialized (SR or Nitto) stem and standard road bars (44cm) drilled for bar end shifter routing. Mix of 500LX and XT parts.
