Switching to code RSC from Shimano
6.9K views 36 replies 22 participants last post by  Amt0571
#1 ·
After a second caliper dying in less than a year with Shimano brakes I'm going to try SRAM Code RSC brakes.
Anyone have any tips for setup or just general tips for switching?
#5 ·
Yes get the pro bleed kit and follow the directions. You will find that Sram are the absolute easiest to bleed and the brake fluid resists boiling.
I have the regular Codes and will be upgrading the levers to RSC's and HS2 rotors to 220mm F and 200mm R when the pads wear out.
Brakes are very personalized decision. FWIW, most guys like myself coming from a moto background find the Shimano too touchy (either on or off) and love the modulation and power of Magura and Sram. I have a finger hovering over both levers all the time.
#9 ·
OP: They’re brakes. You’ll adjust. Everyone has their individual preferences as you see. Here’s how I view it: My preference is Magura. If I buy a bike with Codes, I know I’ll be happy. If I buy a bike with Shimano brakes, I know they’ll be coming off.
#10 ·
I have had Shimano (XT) brakes and have never had a problem. Maybe I have been lucky. I have also had SRAM, but not the latest generation. TRP is getting great reviews and they use mineral oil. SRAM is also coming out with brakes that use mineral oil. IMHO and experience it is easier to handle and to bleed the system.
#12 ·
I know it isn’t the advice you asked for but I put TRP brakes on my bike recently and wholly stopping power Batman they are insane! I also have a trek session with SRAM code brakes and they are difficult to squeeze and I hate them very much. I know it’s all subjective but I will preach and rave about TRP brakes all day
#13 ·
Fully agree brakes are a personal choice. I got tired of the on/off feel of Shimano and the wandering bite point. I have Magura now and really love the modulation, power, no brake fade and one finger lever shape. Not so keen on the sensitivity to alignment. They can also be noisy at times. Rode the code RSC on a demo bike and really liked them. I plan to try a set this spring.
#14 ·
I don't own Codes but I got to use them for a couple of days on a rental bikes during a recent trip and I thought they were awful.
I own TRP DHR-EVO, TRP Quadiem, Magura MT7, Shimano Saint, Shimano XT, Avid BB7 mechanical.
Of all of those, the TRP DHR-EVO are best.
#21 ·
I have a pair of Codes sitting in a box with only 4-5 rides on them. Couldn’t get them off the bike fast enough. Dangerously underpowered.
My trusty Saints went onto the new bike and there they’ll stay. All I ride is steep fall-line trails on that bike, and the Saints are perfect. One finger, never fade, plenty of modulation. Very easy to bleed; all I use is the shimano funnel.
  • Like
Reactions: Nat
#30 ·
Just moved to Code RSC's from Shimano XTR 4-pot brakes. There is a difference in power but there is also a pronounced difference in modulation. It's been muddy and rainy lately and the extra modulation has been useful. But when the weather gets drier and the speeds go faster, I think it will be easier to do late braking with the XTR's.
What I do like is that the lever feel is far more consistent with the Codes. The"wandering bite point" issue is still very much present on Shimano's top shelf 4-pot brakes, although it's not as bad as the previous generation.
Note: Be mindful when you turn the bike upside down or after a tumble (on Shimano brakes). Make sure to pump the levers before even mounting the saddle, especially on steep and rough tracks.
I do seem to get more arm pump with the Codes on technical descents, tho. More mileage on these brakes will hopefully fix it.
Which one do I prefer? For a DH or Enduro race, I will probably want the XTR but my thoughts are that the Codes are better "daily drivers".
OT:For Saints vs Codes, I would go with the Codes 100%. For Shimano Saint vs XTR 9120, I would go XTR's, definitely.
Sent using Tapatalk
#35 ·
I’ve really liked the set of Code RSC on my new bike. In the past, I’ve used XT and Deore 2-pot and Saint 4-pot but exclusively Shimano.
May have slightly less power than the Saints but I love the building power as you pull. With the Shimanos, I didn’t like the wandering bite point and the grabby nature in hindsight. Ultimately, I can use either but leaning towards Codes on my next build if I can find a decent price.
Ive had the codes 1 full season and other than a slight caliper and rotor adjustment, I haven’t had to touch them.
#36 ·
Had the first ride with the Codes this afternoon. I'm happy. They come on slower but also smoother than the XTs when pulling the lever. There is plenty of power, if anything they are more powerful than the XTs (both set up with 200mm front/ 180mm rear rotors) I do like having the ability to adjust contact point and lever position separately.
While I dislike having to deal with DOT fluid, the bleeding edge setup makes bleeds pretty straightforward. No real complaints here.
My only niggle is that the front brake that has a factory bleed is not quite as firm as the rear that I bled after routing the cable internally. I'll likely bleed the front the next rainy day I have off.
