I'm wondering what stanchion grease you keep around for general purpose use. I'd like to get a small tub.
We've had this discussion before. Other than the lubrication that occurs inside the fork itself (via bath oil or grease as mentioned above), I think the consensus was that the upper stanchions don't need lube, just wiping/cleaning. Lube on the exposed parts just attracts dust that clogs the wipers faster.
If that's what you're asking. Otherwise, nevermind!
Thanks guys.If you need stanchion cleaner fancier than a clean rag, try the silicon spray cleaner.
Don't lube your stanchions.
This is what I use. I just put some on my finger and run it along the lip of the dust wiper. Then cycle fork/shock a few times...clean off all the trapped dirt that comes out.I use WPL Forkboost, put a smear on the fork and shock, cycle the suspension and wipe off the excess along with the dirt it brings up from the seals.
