For the newest SRAM type 2.1 derailleures, are there any realistic difference between X9 and X0 besides 35 grams and color?
Thanks for the input. I'm thinking of just getting a X9 then. Where did you get the aluminum screws? Hardware store?I can't find much of a difference when I was looking to switch to SRAM last year. I thought for the price difference it would at least came with some ceramic bearings...but it doesn't.
I got a X9 and replaced the steel adjustment screws with aluminum ones...it weighs the same as the X0 now.
Im thinking of getting an used XX shifter to run the X9 dérailleur. Or maybe I'll give the XTR kit I have a chance.I don't doubt what you are saying since I didn't have two to compare side by side. At the time of ordering I didn't see the additional cost to be worth it for what you'll be getting with the X0. What else is different besides the C-clips? There has to be more for the 100+ dollar difference? The SRAM site doesn't say too much.
I am using an X0 shifter. So the money I saved by going X9 with the RD...I went X0 with the shifter...where I feel that it'll make more of a difference.
I don't think the type of bearings in the pulleys makes muck difference, if any. Cartridge bearings in there seem overkill as the plastic teeth will wear out long before the bearing irrespective of what they are.XO Type II has cartridge bearing pulleys, X9 Type II has plain bearing (bushing) pulleys. XO (Type 2.1) plate & pulley tolerances are tighter out-of-the-box than either of my two previous X9 Type IIs.
...What else is different besides the C-clips?...
macming and RS VR6 asked for objective differences between models.I don't think the type of bearings in the pulleys makes muck difference...
I can't see play in the pulley causing that. Sticky clutch, yes. I've ran very worn and loose dérailleurs and I've never seen that happen. In fact Shimano top pulleys have lateral float designed in. That looks like a combination of crap clutch and crap cage/pulley design to me. If the teeth are not worn there is no way the bearing, of whatever type, should be worn enough to allow that. It's the design itself that has let that happen.On my first X9 Type II, a combination of lateral pulley play and grabby Type II clutch contributed to the chain walking off the lower pulley and wedging between pulley & cage.
Not in my two Type2 RD's. Both had same pulleys equipped with sealed industrial bearings. Zee had bushing pulleys, now it has Tacx T4060 pulleys which are better than SRAM ones.X9 Type II has plain bearing (bushing) pulleys. XO (Type 2.1) plate & pulley tolerances are tighter out-of-the-box than either of my two previous X9 Type IIs.
I've worn the teeth down to nothing on Shimano pulleys but the ceramic bearings were still fine. I really don't see any need for a cartridge bearing in there considering all it does.Zee had bushing pulleys, now it has Tacx T4060 pulleys which are better than SRAM ones.
Having pulleys which have proper bearings keep RD shifting as expected even when pulley teeth are very worn out. And bushing bearings get very restrictive when soaked in wet mud etc.I've worn the teeth down to nothing on Shimano pulleys but the ceramic bearings were still fine. I really don't see any need for a cartridge bearing in there considering all it does.
Your jammed up SRAM looks very new and clean though...And bushing bearings get very restrictive when soaked in wet mud etc.
