bit of a head scratcher here so any help in advance is great!
I think I've spent more time than anyone in the world now reading about the various offsets for their threaded chainring options when installing the transmission power meter spider.
I'm running a S Works Epic Evo (which according to specialized is 52mm chainline). The bike came stock with the XX SL Eagle Crankset in 168mm Q Factor with a 32T 0mm offset chainring. (I even verified the Q factor with Sram via the serial number on my cranks) and so based on everything I've seen I should get the 3mm offset right? this page on power meter city (screenshotted below) is great ...... (also this screenshot below from SRAM support).
Problem is, when I installed it all shifting went to hell, the installed chainguard no longer fit and so I swapped it for the 0mm offset (i'd ordered both) and whala, works perfectly. Any idea why this is? I even went to the local Specialized dealer and looked at a bunch of their EVO and Epic Evos with the new power meters already installed and they all have the 0mm offset threaded chainrings. A few friends have all said 0mm offset is how they're running, so I'm wondering why SRAM and everyones literature is so off on this.
