SRAM Guide caliper blocks mounting bolt?!?
16K views 25 replies 15 participants last post by  alkalifly
#1 ·
I just got a new bike outfitted with SRAM Guide R brakes. This is my first experience with SRAM brakes, so I'm not sure if this is a well known problem, or if I'm just missing a simple solution.
The problem is that the caliper body gets in the way of inserting a hex key straight into the bottom mounting bolt of the front brake. The image below shows this; the red line represents the end of a hex key trying to go straight in, and you can see that it crosses the caliper body!
I can get a key in there at a bit of an angle, which does allow me to turn the bolt, but not with enough precision or grace. I'm trying to align the caliper because the rotor is rubbing, but having the hex key going in at an angle makes it so the caliper gets pushed around when I'm tightening the bolt, which screws up my alignment attempts.
I have an L-shaped key, but the short side is still too long to clear the caliper. Do I just need to find a hex key with an even shorter side? Can I remove the spacer, which might give me enough clearance to get the short side in? Any other creative ways of dealing with this that people have found? Thanks in advance for any suggestions.
#5 ·
Make sure the pads are aligned with the rotor correctly. Thats not right for brake calipers to be covering access to mounting bolts. There is technically torque specs for those bolts and that means coming on them straight.
Be helpful if we had a full picture of caliper, adapter, fork all together.
Sent from my SM-G950U using Tapatalk
#7 ·
Cobba, you missed everything I was explaining.
If the caliper is improperly spaced and at a bad angle it can cause the issues hes having.
Some bikerumor review picture is totally useless, need to see what his set up is as it doesnt seem right a straight allen wrench wont fit correctly. Though this is sram were talking about....
#9 ·
Ah, I missed this last post of yours while I was uploading my photo. I didn't realize it was a review pic, I thought maybe he had taken it of his own bike. But either way, that photo seems to illustrate the same problem that I'm having. If you draw a line straight out from the lower mounting bolt, it is going to cross the caliper body.
#17 ·
Yes. Ball end hex keys are good in this situation. In other situations (softer lower grade bolts, smaller sockets at higher torques) it can be easy to strip out the bolt's socket because the ball only engages a very short length in it. I've also broken off the ball in a bolt, and it can be near impossible to get it out.
If you're using a torque wrench, the relatively small angle between the axis of the key and the bolt won't consequentially affect the torque reading.
One other thing you can do: Where the torque key would contact the caliper, you can grind a wide groove around the key to clear the caliper.
#20 ·
That is really weird. I have guide R's and have entirely removed the front brake caliper and put it back on without running into this. How old is this brake set? Mine is a relatively recent iteration (just purchased 2 months ago).
#21 ·
I don't have this issue with mine. Looking at your picture and comparing it with one of mine and the other one shared here, it kind of looks like the top part of the caliper is a little further away from the fork than it should be. Which means the pads are not in line with the rotor correctly. The arch of the pad should line up perfectly with the top of the rotor.
Can you post a picture from the back side of the caliper that shows the pads sitting on the rotor?
If this is the case, then it would explain why you're having issues with access to that bolt. I had to order an adapter set for mine when I bought them. My existing adapter was off by a millimeter. Picked up the below set from amazon.
https://www.amazon.com/gp/product/B009P3LYU8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
#23 ·
That's odd, does look like that's just how its made. Fwiw the Guides that came oem on my intense have just enough clearance to get at the bolt straight on. Also the bolts are nice and flush on mine without the swively spacers. I understand the idea behind them but can't see how they are needed on my bike. Maybe with a different rotor size and adapter size they matter. I run 203mm with shimano adapters
Sent from my Nexus 6 using Tapatalk
#26 ·
OP here. Thanks to everyone for their helpful responses. It seems the upshot is that this is just a design flaw in certain revisions of the Guide brakes. Lots of good suggestions here helped me out. Between a ball end hex key, a short legged L shaped key, and a willlingness to scratch the caliper a bit (cosmetic only), I got everything nicely aligned and spinning quietly. I will ride these Guides out for a bit, but will most likely end up back on Shimano brakes soon enough.
