Specialized Chisel discussion
1 reading
997K views 2.6K replies 383 participants last post by  msrothwe
#1 ·
#107 ·
OK, maybe I can get the words right without misleading anyone.....After riding the Chisel ten miles today on a somewhat rooty somewhat rocky trail today I am feeling that the bike does ride differently than the 3 Stumpjumper hardtails I owned. It is more subdued-- meaning calmer-- on the bumps than the SJ--- given the same fork pressure, tire pressure, etc. I'm guessing the longer wheelbase is involved along with the head angle being more relaxed. The bike seems really solid. The wheelset is heavier than the ones I have been using for years (Stan's Crest; Stan's Race Gold, Stans Arch....I have all three available for my 2014 SJ Evo Expert 29er full suspension)--- but the wheelset is solid and I do not feel the flex that I feel with the Stan's wheels.
The one thing I particularly like about the bike is how it feels when I stand and hammer the pedals. The cockpit feels roomier than the SJ 29ers; I can move around more without getting too far forward so easily. The bike is (to me) obviously/significantly better downhill than the SJ's.
That's all for now.
#110 ·
That's all for now.
Good feedback! Thanks!
#109 ·
I would assume the stock wheels are around 1800 grams (thats usually pretty accurate on their lower level builds like this)
Any stans set should do you pretty well. You could also probably score some lightly used carbon rovals for about that much.
#116 ·
hesitationpoin it looks (and I am not the expert) that the Epic Comp uses the Control rims but not the Control hubs.
From reading the website it looks to me as if Specialized is using a variety of different combinations of their wheel and hub components on their lower end Epic bike and ones like the Chisel. Not sure the wording is consistent on some of these.
#118 ·
I think you are right. The $3800 epic clearly states roval hubs but not the $2500 version (I have a printout for the 2018 which sells for $2500).
Specialized also emailed me and told me the 2017 Epic hardtail for $2600 weighs 24lbs for a large. hmmmm....decisions.
#117 ·
Tyrich88 I might add to my discussion that I have been around the circle as to mountain bikes, going from 26 hardtails all the way to the full suspension 29er. When I finished racing 3 years ago I was on a 23 lb full suspension Specialized bike that literally ate the trail while I pedaled as if I were in a spin class. The trail in most cases no longer was challenging. The really light 29er hardtail SJ had been surpassed by the new precise dual suspension technology. I quit racing; I love simplicity; I am delighted with the Chisel because it is simple, inexpensive, and the weight is reasonable. The GX groupset is at least one pound heavier than the best available 1x11 groupset; the wheelset is at least one pound heavier than many upper end wheelsets; the frame is about a pound heavier than the Epic carbon hardtail; etc. But I like the ride of a 25 lb hardtail and I love the ride of a 25 lb hardtail with a slightly slacker front end with a tad more suspension. With the exception of going uphill in a race...to me a 25 lb hardtail rides far better than my former 22 lb racing hardtails--- particularly those older hardtails with 71 degree front ends. So I ride the bike by choice. I'm older, the exercise is great for me.
#140 ·
I can absolutely understand where you're coming from. I have a rigid single speed that I had down to about 18 lbs a while back and i've since added some other parts to it and have it around 20+ right now and it rides so much better! Doesn't bounce around on top of the rocks as much, stays planted and handles better because of it.
I'm coming off of a 22lb carbon Epic WC, so i'm very excited to see how this bike fills that void.
I've got a really good build lined up for it so i've got some high hopes!
#124 ·
Weighed stock in the shop includes tubes, front reflector, rear reflector, the plastic chain retention thingy that liters up the inside of the cassette, and those plastic pedals. My bike the 1x11 Expert model, tubeless with those 740 gram Fast Trak tires, two bottle holders, Crank Brothers Eggbeater 3 pedals (266 grams), and a couple of Allen wrenches fixed under the seat weighs 25 lbs. The bike without pedals will - as poster ExhaustPipe displayed - come in just over 23.5 lbs tubeless and a tad over 24 lbs with tubes ex those plastic reflector/chain retention parts that you take off to keep from being embarrassed.
So running Renegade 2.3's should get the bike weight down to about 23 without pedals.
By the way, for anyone considering the bike, I consider the 1x11 GX SRAM drivetrain easily the best I've ever had. I have XTR, various years older stuff, on all my 5 other bikes.
#143 ·
I was too lazy to pull the cassette off, so no not yet haha.
I was hoping someone would chime in and say "Take the front wheel weight and add XXXg to get the approx rear wheel weight"
edit: oh yeah, the disc was still on the front wheel when I weighed it... oops
Disc doesn't usually weigh that much... maybe 100g.
With a 875g front wheel... the back wheel is probably 1100-1200g. Really depends on the hub they are using though. either way thats a pretty stout wheelset.
Weighed my control SLs yesterday with plugs (never used plugs before and it came with them, figured i would try them instead of rim strips) and valve stems and they were 1383g so that automatically drops about 1.5 lbs off of the stock weight just from wheels! I also have an x01 cassette that is about 260g vs the ~530g of the NX cassette.
Run some lighter tires than those new specialized ones and you're dropping 2+ lbs pretty easily with lighter wheels, tires and cassette.
#144 ·
you are pretty much right on. I took the cassette off and weighed the rear wheel with tire/tube/disk. It was 2150g. When you back out the weight for those components (approximately) you get a 1050+/- gram rear wheel. 1950g +/- wheelset.
#146 ·
Ive enjoyed reading everyones planned builds for the new Chisel. I am still patiently waiting for the frame only to become available. Sounds like it will still be another week or so. Anyways my current build list is:
Rockshox SID RLC
Sram GX Eagle w/ Raceface Turbine
crank
SLX M7000 brakes
Stans Crest MK3 w/ Hope Pro4 hubs
Sworks bar and seatpost
Sworks Phenom saddle.
Cant wait to see everyones finished builds!
#153 ·
Finally......
Finally completed my chisel built. Got my wheels laced today. It was way off the 10kg mark. Very happy. Can't wait to ride it this weekend. Carpark test didn't say much, except I feel the stem Abit long at 80mm. I tested the small stock that comes with a 70mm, should have gone with a 70mm.. Well here it is.. 8.86kg with pedals! Disco disco
#158 ·
Omg!
S
View attachment 1152651 View attachment 1152652
Straight Sexy!
