1 - 20 of 57 Posts
It depends how much of a craftsman you are.
I do it all the time, and have never bothered to make a tool for it.
On the other hand, you can mess up pretty bad, even bad enough to damage your frame.
Don't get this wrong, as no offense is intended, but if you have to ask, you should probably have somebody help you who are able, or have it done by your LBS.
if you'd like a walk-through, drop me a mail, and I'll happily try to help you understand how to.
Magura :)
coiler_guy said:
it's super easy to make your own headset/bearing press. I just did it on my bike. I am going to put up a post in my blog the next few days with some pics. I'll post again here for your reference.
Make sure you post your link here. Thanks.
To OP. I have never messed it up, I don't have a tool for it either.
You can damage the frame or the headset or both if the cup goes in on an angle.
Which gets damaged depends on which is tougher. XC frame and steel cup....
DH frame and Alu cup....
Make sure your headset uses alu cups, then at least you have a good chance of breaking just the headset and not the frame if it goes wrong.
If your headset is weak alu, and you intend to bash it in with a mallet and piece of wood, then of course you could damage the cup just from bashing.
So, the press is a good idea. But usually ends up costing to make. However, looks like coiler_guy is about to solve that problem for you. Worth making the press, as you'll use it again.
If you mess this up, don't keep going in the hope it will be ok. Knock cup back out as soon as it goes off kilter and try again.
The headset remover tools are cheap. Have one ready. Get one that does 11/8 and 1.5. You can make them work better by shoving a piece of cut steer-tube up inside them as you're using them. This keeps the ends of the arms on rim of the headset cup. Better to hit it a medium number of medium hits than a few big ones. Big hits can make sudden, major chances and those can break stuff if the result is not right.
You will find that you need to hit things harder than you expect. But, better to build up to that level from below, and learn what it is, than to exceed from the get go.
Use some good grease to install headset.
Make sure you cleaned out any overspray inside your head tube first.
5/8 threaded rod longer than your head tube; 2 5/8 nuts and some hard washers . Use the nuts and washers to squeeze the races in. I also ground 2 flats on a 5/8 washer so it fits through the old races, but contacts when laid flat inside the headtube, then pound old races out. Has worked for me several times.
It is not difficult to press a headset, but you can damage the frame. You have to be willing to accept that risk. If not willing, then pay a bike shop to accept the risk.
I use a threaded-rod setup that I bought from user "mtbtools" on eBay:
http://cgi.ebay.com/Mountain-Bike-R...s-Toolset-/260475781192?pt=LH_DefaultDomain_0&hash=item3ca5910048#ht_500wt_1085
Maybe I could buy all the same parts at the hardware store, but this guy has everything ready to go, and that's worth something to me. Plus, his aluminum press drivers fit perfectly inside the bearings on Cane Creek S-3 headsets, helping a lot to keep everything lined up.
Be generous with the grease. Press one headset cup at a time. If a cup begins to go in cockeyed, then use the remover tool to knock it back out so you can try again. However, the cup will not necessarily stay 100% perfectly aligned during the pressing process either.
Depends on your skills and how careful you are, some people have installed dozens of headsets with nothing more than a hammer and block of wood and gotten it perfect every time. Others...well, let's just say it ended with a frame & headset write-off. I've installed everything from a $10 used box special to a set of Chris Kings with the hammer & wood block technique, so far, so good. I keep meaning to make a headset tool of some sort but I never get around to it. And yeah, grease is your friends, lube up the frame & cups and everything goes in nicely.
Find a cheap $10 bike at a garage sale or something, or maybe pick up a free one from the curb on garbage day. Bash out the headset cups with a screwdriver or some other tool then try to put them back in. Do it a few times and if it goes well each time then you should be able to install the headset on your good bike without too much difficulty. If you keep messing up, you know it's best for someone else to do it for you.
Yeah you could mess up your frame, but honestly, you'd have to really screw it up. Bang that sucker in with a 2x4. If it starts looking crooked, quit banging!
Any grease that is slippery. The objective is to just get that thing in place without having to knock the crap out of it.
I have pressed all of mine in using my fork. Put the bottom part of the headset on the steerer, put the fork in the frame, put the top stuff in the top. Use stem, spacers, and the topcap ... screw down, repeat adding spacers to get it in there ... almost guaranteed straightness.
Not sure if it's a great idea, but I've had good luck. I have only used sealed bearing headsets, though, so I am not sure if that matters.
Oh ya, if the frame is new, you might want to consider having the headtube faced.
That's an interesting technique. I wouldn't have thought of doing that. It's a clever hack though. I like it.
As promised here is my headset press. It is very similar to the threaded rod style with a few mods that I think make it work better. Those mods would include using 2 wood blocks and keeping on of the blocks stationary. this method works great and there is very little risk of damaging anything IMO. take it slowly at first and make sure the cup is going in straight and you're good to go.
here is a pic of the completed tool.
You can see a complete write up here:
https://bikelife365.blogspot.com/
hahdtail said:
what kindof grease mates?
Valvoline syn power synthetic automotive grease has been my favorite flavor, but any grease will work. It's not a good idea to mix, so clean everything and use the same grease that you pack your bearings in.
True, just about any kind of grease will work.
The important part is that the grease must be SUPER CLEAN! As in no contamination of any kind.
Keep grease in a gun or similar, use clean rubber gloves, and keep your workspace ultra clean when working on any kind of bearings.
The usual bucket of grease with a paint brush standing in a corner of the bench, is a sure way to keep things at their worst. I know that is frequently seen at the LBS, but it is a sure no-go.
Magura :)
I'd recommend against it. When you assemble the headset first like that, you're actually pressing it in via the bearings, which isn't a great idea. Also, if it's a difficult press (longer skirts or tight interference), then it's hard to get enough torque to completely press the cups in.
dundundata said:
i'll most likely be giving the ghetto method a try when I get a new fork. I like the idea of the threaded bolt and washers for the cups, some cut piping to remove the old cups and a pipe to install the crown race.
I tried to upload some pics, but they are too large, 488mb only, c'mon mtbr!:madman: My threaded rod idea also removes the old races. A 5/8 washer just catches the races and clears the i.d. of the headtube. Grind 2 flat sides opposite each other on the washer and it will slide in vertically but lays flat on the races inside the tube. Put a nut on the 5/8 threaded rod, then insert the nut/rod into said ground washer and pound the race out. Comes out straight and clean every time.
1 - 20 of 57 Posts
