This post is quite old, but thought I'd share my recent test results comparing Maxxis Ikon 2.20 60tpi Tan Wall vs Ikon 2.20 120 tpi Black Wall and a CrossMark II 2.25 60 tpi Black Wall. All tires are EXO/TR and the Ikons are the 3C. I'm comparing to the Crossmark because it is the lightest 60 tpi black wall xc tire I can find from Maxxis. On my scale here are the tire weights:
Ikon 2.20 Blackwall 120 tpi : 680 grams
Ikon 2.20 Tanwall 60 tpi : 715 grams
CrossMark 2.25 Backwall 60 tpi : 785 grams
My tests are essentially conducted in one location, at Lake Pueblo State Park in Colorado, which has a lot of sharp, splintered and embedded shale shards on the trail. I have hundreds of hours on these trails with many different Maxxis tires over the past five years and know the trails well.
I've only ever cut rear tires, and never a front.
If I run any Maxxis 120 tpi tire I can expect a catastrophic side wall cut in 10 hours of trail riding. In my tests these are the Black Wall tires. I've tried picking lines extremely carefully, unweighting the bike in risky sections, and changing tire pressures, but the results have been pretty consistent. I'm pretty well guaranteed to ruin a rear tire within 10 hours of trail time.
If I run the Maxxis Ikon 2.20 60 tpi EXO/TR Tan Wall I get much better results than any 120 tpi tire I've tested. However after about 20 hours the tan side walls are showing severe abrasion with exposed threads and a few near failures.
I have had the best results with the Cross Mark II 2.25 60 tpi EXO/TR. Over the past 5 years I have cut one tire, and that cut was small enough I was able to repair it. But I'd estimate I've gotten well over 60 hours on this tire without failure.
From these failure results and close inspection of the side wall wear, I believe the Back wall tires are more durable to sharp rocks than the Tan walls.
Having said all that, the reason for all my tire testing is to find the lightest tire with the best feel that will hold up on my trails. The lightest 120 tpi tires have the most supple feel and perform very well at low pressures. And the Cross Mark II at 785 grams has the "worst" feel of the tires I tested. I'd say the Tan Wall Ikon was very good in terms of ride feel, closer to the 120 tpi tires than the Cross Mark II. For racing on high risk trails I may opt for the Ikon Tan Walls. But for day to day trail riding I'll stick with the Cross Mark II on the rear in the Black Wall material.
