Shimano SLX 7120 brake lever blade replacement - lever axle stuck
1 reading
26K views 20 replies 10 participants last post by  jaybert
#1 ·
Unfortunately snapped the lever off my SLX brakes this morning. Looked at some online guides and videos to remove the brake lever for replacement
1) Remove rubber cover for grub screw
2) Remove grub screw (2mm hex)
3) Lever axle should slide out when pushed
I'm stuck between 2 and 3. Removed the grub screen but axle is not sliding out. The lever also doesn't look the same as some of the guides I've seen online for Shimano's other brakes (XT, XTR). The videos I've seen, people push the axle up to remove it, but from the bottom of the lever (3rd photo), doesn't look like the axle can be pushed through the bottom? Tried to push the axle from both the bottom and the top, and neither way is working so far.
Pictures below, would very much appreciate any tips!
IMGUR:
#2 ·
If you look at the axle itself, from above and below, you will see that the upper side is bigger in diameter - that's the head of the axle.
You need to gently tap on the axle from below with something thinner than it to push it out.
Y2S798010 is Shimano product code for SLX lever blade right.
No other blade is compatible than this one.
And left blade is not flippable.
#4 ·
My SLX axle was in snug as well. As long as that little locking grub screw is removed you should be able to punch the axle pin out. I supported the master cylinder on a wood block and gave the underside of the axle a good tap using a appropriate hex bit as a punch (all my major tools are at my folks place, damn Covid!) and a small hammer. Once it pops loose, you can push it out with a hex wrench etc.
@Groove_c do you know if you can use the M8100 XT levers in the M7100/M7120 master cylinders?
#12 ·
I've been wondering what makes them L to R specific?
I cannot see any difference except the small spring (which can be reused). The spring is side specific but I cannot tell what is different about the levers.
I haven't tried switching them but I suspect that as long as you use the spring from the correct side, they'd work.
#14 ·
FWIW, I got curious and tried swapping my good right lever blade to the left and it worked perfectly. All I had to do was use the small spring from the left and it worked perfectly.
Also tried installing the broken left blade in the right lever and again, worked perfectly just so long as I used the right side's spring.
So my results, the levers aren't side specific but the spring is.
They're typically sold in a set with the spring. They call it a "member unit". So if you can reuse your old spring, you should be able to use either lever blade in either side.
#15 ·
Damn, that's good to know. Thanks for doing the testing.
I was looking at picking up a spare left lever and everyone was sold out. Might get some 8100 blades if/when I break my current ones. Kinda like the dimples.
#18 ·
Confirmed, they'll work. Check out these threads.
and
