I finally bought one of these for my commuter. I searched diligently to find reviews for this hub before I bought it, most of what I found turned up here.
This is the Shimano SG- 3D55 3 speed hub. 32 hole, 135mm, centerlock disc-ready, purportedly having a silent clutch (more on that later). The only production bike I've found to have this hub was a Specialized Globe model from a couple of years ago. I've been riding a single speed for my commute to work, but it's a bit of grind on the hills, especially when it's raining and blowing. So I built this up.
It's the Salsa single speed Casseroll, which I've fitted with the 3 speed hub. The Salsa has forward facing horizontal dropouts, which is ideal since you can remove the rear wheel without taking off the rear fender. I don't have much experience with IGH's although I did test ride an Alfine 8 speed at a local bike shop. The Alfine works well, but it's quite chunky and I didn't want a grip shifter. The SG3d55 is relatively cheap, $125, add a shifter and bell crank for about $20. It is also about a pound lighter.
The SG-3d55 has gearing that is the same as all other Shimano 3 speed hubs. 1st gear is .733:1 second gear is 1:1 third gear is 1:1.36. I am running 48t/19t cogs, which results in drivetrain gains of 1.85, 2.53, and 3.44. The gearing is fairly widely spaced, about the same as shifting from your smaller front chainring to the big chainring on a typical road bike (39t/53t). I ride in second gear the most. Overall it works pretty well, though sometimes I find myself wanting something in between 2nd and 3rd gear.
Shifting. Upshifting is good. Moderate load can be applied to the pedals and the bike will still up shift quickly and quietly. Downshifting . . . not so much. For a clean downshift you pretty much have to pause in pedaling for a clean shift. Seems to be more of an issue for shifting 2nd to 1st than 3rd to 2nd. Just like any of the current cruiser bikes, the bell crank translates the cable pull of the shifter into a pushing force against the pushrod within the axle. Lateral position of the push rod determines what gear the hub is in. The bell crank is fixed by a set screw. Removing the rear wheel first requires removing the bell crank, then loosening the axle nuts. I didn't want a grip shifter, so I dove into the old parts bin and found a Suntour 7speed indexed downtube shifter. Coincidentally, 2 clicks on the suntour works out to one gear on the shimano hub. With a little tuning, the system works pretty well. I run a bare shifter cable from the shifter, under the BB and straight to the bell crank -- no cable housings. This makes for a crisp system.
Aside from the option for a disc brake, the biggest selling point of this hub is the "silent clutch". Well, that claim is only partially true. The hub is truly silent in first gear, both coasting and pedaling. Second gear is typical hub behavior, silent while pedaling, ratcheting while coasting. Third gear is . . . a disappointment. The hub ratchets both while coasting and pedaling. Not so silent. As far as I recall, the Alfine does not have this problem, so it's certainly possible to design around it.
Overall, I like the hub. I think the simplicity and compactness of the 3 speed IGH is perfect for commuting. Fewer moving parts than an 8 speed, so less to go wrong. While the external bell crank is not very cool looking, it works well and wheel removal is easy. The gearing works for me pretty well, if anything it could be a bit closer spaced, but it works fine as it is. The biggest annoyance is the ratcheting in third gear, which is only slightly moderated by the fact that I use this gear the least. Improved downshifting would be nice as well.
