21 - 30 of 30 Posts
Really enjoyed reading this. I, too, am a Newbie, and love learning from threads on this forum.
:thumbsup:
nobody told me when i started riding. i kept snapping chains and couldn't figure out why. i also didn't know that cross chain was bad. or that your chain stretches and if you run it too long you will ruin your entire drivetrain (cassette, chainrings, and chain) and have to replace a bunch of more expensive stuff instead of just periodically replacing your chain. all it takes is a $10-15 chain gauge and check it every so often. when it gets worn, replace and repeat.
be nice to your bike parts, they take a beating most of the time.
Tip: Always scan your road and look ahead for what you might encounter in the trail. Select your gear early before you hit the climb. This will save you from damaged parts and damaged knee ;)
If only it were that simple. :)
If you are new to a given trail, and there's a hidden climb around the corner, you'll inevitably be mis-geared. Just the way it is. You can either try to brute force it if short enough in the big gear, or maybe slack things enough for a split second to get a clean gear change in. Or walk.
21 - 30 of 30 Posts
