After servicing my "spare" Rockshox Duke XC last week, I got courage to do a basic service (cleaning, oil change, etc) to my "official" Manitou R7 absolute...
These are not my real photos, but they are exactly the same scene
I started by complete disassembly :
Then I took out the Platofrm valve :
But to put those foam blocks back to the fork, I got them damaged a little... Will this hurt the plush feeling of suspension ?
Also, maybe I've put a little more oil than this :
I think I left oil level at the same level of the thread... is this so bad ?
I took out an spacer in the lower side of air leg (left side of this photo)... it was 15mm long.. is this a good change ?
After putting all together (oil both sides, grease, ai, etc), everythink looks fine and it works well, but the fork is not more plush tha before... it still needs some weight to start working, like it has some inertia due to bushing or lack of lubrication in the lower legs (i've put ATF oil on it, according to the instructions)... is this normal ? Is there anything I can do to make it better or Manitou is just like that ?
Thanks a lot !
Anderson Cunha
Thanks a lot !
Anderson Cunha
