Seatpost sizes of mid 80s Mtbs
3.9K views 4 replies 5 participants last post by  Nomad77
#1 ·
I want to get a vintage mtb to throw some parts I have laying around on. I was wondering do any of the frames from the early to mid 80s have 26.8-27.2mm seatposts or was that a later thing?
#4 ·
27.2 was (is) a normal Reynolds ID, and many (most) MTBs of the time were not built with Reynolds tubing. 26.6, 26.8, 27.0 were by far the most common, in my experience. As time progressed, 27.2 IDs on seat tubes became de rigueur on steel frames.
Specialized and Trek both had models that had 27.2 seatposts. If you expand your search into the 90s, 27.2 will become much more common.
Note, you CAN use an expandable reamer to open up a seat tube, but you need to choose your target carefully. [Cheap] tube walls are usually not much more than 1mm at the top on steel frames, and you would have to remove 10% of that to open a 27.0 to 27.2.
