So we are seeing a handful of pro EWS riding on Lyrik Ultimate forks. Predictions?
So RC2 recalibrating and some sliding/sealing upgrades.Translation from a Taiwanese website:
Lyrik Ultimate combines the fully recalibrated Charger 2.1 damper, the new SKF seal ring, and Maxima Plush damping oil for smooth, smooth movement, allowing the front fork to maintain a high stroke during compression while returning the tires close to the ground, achieving unparalleled handling. With the new Charger 2.1 RC2 damper, riders can find the perfect adjustment settings for their riding environment.
*Features / Benefits
. Newly recalibrated Charger 2.1 damper for higher level compression and rebound control
. New low friction SKF seal ring and damping pod seal ring
. New Maxima Plush damping oil reduces friction and improves smoothness
. New signature "BoXXer Red" color scheme
. New Ultimate High Polishing Sample
. Charger 2.1 RC2 damping element with independent high speed and low speed compression damping adjustment
. DebonAir air spring reduces the friction of each moving part and enhances the bounce absorption effect. Even under heavy load, the reaction is flexible and greatly reduces the rider's control burden.
I'm thinking of going this route. It's a good fork but I am still struggling to find a tune that feels supple enough on moderate chunk without diving on huge hits.Rockshox needs to quit tweaking and modifying the charger and go with a full redesign. Otherwise, I don't feel very confident throwing my money at anything they release. The new debonair upgrade was nice, but still just a bandaid. The RC2 upgrade has been temping, but I don't feel it is worth the cost. I'd rather save my $300, sell my lyrik, and buy a 36 grip 2.
Ahh yes you are correct, hadn't realised that the dropout would be different for 27.5 as that's what mine is. Do like the new graphics thoughYour probably looking at a 29" Lyrik in the pic and the cached site is 27.5, just a guess though
More interesting is this bit for the Lyrik Select:SRAM said:Lyrik Ultimate combines the completely re-tuned Charger ™
2.1 damper with new SKF wiper seals, SKF damper cartridge
seals, and Maxima Plush fluid for a buttery smooth
feel while allowing the fork to ride higher in travel on
compression keeping the tires planted on the ground on
rebound for unmatched control. With the new Charger ™
2.1 RC2 damper, riders are able to find the perfect level of
adjustment for their ride.
FEATURES / BENEFITS
• NEW Completely re-tuned Charger ™ 2.1 damper for next level compression and
rebound control
• NEW Lower friction SKF Wiper and Damper Cartridge Seals
• NEW Maxima Plush damping fluid reduces friction and improves smoothness
• NEW Signature "BoXXer Red" colorway
• NEW Ultimate high gloss graphics package
• Charger ™ 2.1 RC2 Damper featuring independent high and low speed
compression adjust
• DebonAir ™ air spring reduces friction from every single moving part,
improving bump absorption and response under load, and drastically reducing rider fatigue
Which suggests it now has a working LSC needle.SRAM said:• Charger ™ RC Damper featuring low speed compression adjust to firm
