Been using several ROGUE tools for years.
The following tools have been my go to for 40+ miles of hand cut trail over a variety of terrain in the past 3 years.
Approx 600 build/maintenance days on the tool mix below. Based on wear and tear and current condition there's likely another 600 days in store for them. They just keep going.
Travis 54"
Travis 48"
55A 42"
60A 40"
85H 40"
For general maintenance and building in moderate terrain, the Travis is an amazing tool. Moves a decent amount of dirt, the pick can pry/move big rocks and bust hard soil, the rake is fully functional and the scraper blade is great for shaping. It's a heavy duty tool with lot of surface area and tamps dirt very well. Best "do everything" tool I've used in 30+ years.
Really shines for maintenance although it is fully capable of lots of initial build work. 7" hoe digs deep and moves a decent amount of dirt. Scraper blade also moves a lot of loose soil and shapes terrain very well. Rake is on the smaller side, but very functional. 11 out of 10 times it beats a standard Mcleod no matter what trail building you are doing. Choose handle length depending on terrain.
55A is an amazing "sleeper" tool. Super light= can carry and swing it all day long. Small size and low weight means it doesn't move a bunch of dirt or do final shaping and tamping well, but it is a great tool for roughing in lines, moving rock or being the lead on a build crew in steep terrain. Weight is 3lbs +/- and you can carry it anywhere. Great tool for benching in super steep terrain with the 42" handle. Amazing what you can rough in with this tool with minimal effort. If you have a follower working with you with a legit shaping/tamping tool it is amazing how quickly you can bench in steep and rocky terrain. Super burly tool for the 3lb weight. I've leveraged out rocks well over 100+ lbs and seen the handle flex to a super sketchy degree but this little tool just keeps going.
60A with the 40" handle- amazing heavy duty steep terrain bench and rock moving tool. Doesn't move a ton of dirt but it does move dirt, cuts deep and remove big rocks. Not a finishing tool but a super burly tool for moving dirt and rocks that can be used all day long. Very light for what you can do with it. Does what the 55A does, but noticeably better for steeper terrain, moving a bit more dirt and bigger rocks.
85H 40" THE BOSS- specialized tool for moving lots of loose and poorly compacted dirt in steep terrain. Easily moves an amazing amount of soil. It's heavy. Benches like nothing I've ever seen in loose soil. Cuts roots and brush in one swing. Head has enough surface area to move lots of loose dirt and to tamp tread very well. Take some time and apply precision and you can leverage big rocks out of the ground as well. Amazing how much dirt can be moved with this tool. Sharp edges make a big difference in efficiency and effort required. Takes a fit and strong user to utilize it effectively otherwise it just wears users out and efficiency declines. For a dialed builder, it can move a ton of dirt and shape tread in steep terrain like nothing else. Best to follow it with a McLeod/Travis or other finishing tool. 2 person crew using this approach in steep terrain can do amazing things.
I have yet to break a Rogue handle or head.
I have severely dinged the cutting edges of all tools and have gouged and chipped all handles.
A hand file can clean things up with a lot of effort in about 1/2 hour. However, an angle or bench grinder with the appropriate attachment does it in minutes.
I sand the handles once a year and use a wipe on varnish for weather proofing. I'm building several days a week and always wear gloves so I don't go in for the tung oil/linseed oil artisan program. Tools are stored out of the weather. Sand handles, wipe on varnish and get back to work the next day and all is good.
Tool weight and handle length for the specific terrain have been a very big deal. Sure, you can "choke up" on a long handled tool in steep terrain, but having the appropriate handle length, blade width/style and tool weight for the terrain and soil makes a HUGE difference.
The amount of energy saved and the efficiency gained for having the right tool for the trail project is a very real thing.
There's lots of crossover in building tools currently and several tools can adequately meet a variety of needs.
However, Rogue/ProHoe offers both specialized tools and and amazing do everything tools.
Good pricing and hassle free shipping when you order directly from their website.
Love their stuff.
If you're already on the Rogue program, then likely none of the above is news to you.
If you have yet to get a Rogue tool in your hands and put it in to dirt, then you owe it to yourself and the riders you are building for to check out what they offer.
https://roguehoe.com/
Travis 54"
Travis 48"
55A 42"
60A 40"
85H 40"
Love their stuff.
