The Ripmo blipped on my radar. I'm 5'9" and right on the medium/large line. Anyone my height have any thoughts?
Any general sizing musings?
I'm the exact same size. Share your sentiments as well.Finally got onto a Ripmo!
I'm 6'.5", 0 ape index. I ride an XL Gen 3 Ripley LS with a 50mm stem and 780 mm bars.
I rode a L Ripmo with a 50 mm stem out of Ibis's HQ last week. I was worried I would feel "pinched" as has been common on other Steep SA/Slack HA size L bikes I've ridden (Spot Mayhem, Pivot Firebird 27.5). This wasn't the case on the Ripmo. Felt great! Sure I could dial in the cockpit, but after 34 miles and 4,500', I felt super comfortable, and the bike was nimble over pops/drops and tight turns. Curious what an XL would have felt like.
The Ripmo pedal response felt a bit slower than the Ripley- I'm sure in some part credited to the Aggressor/Minion combo vs. the Nobby Nic/Hans Dampf combo on my Ripley.
I'd like 10mm of more clearance so I could run 180mm cranks, like I used to before this low BB thing started...I kind of wish the XL had 5mm more clearance for the 175 cranks us big guys run.
I'm 183cm and leaning towards the large for the same reasons. How much seat post do you have showing? I have like 70mm with a 170mm dropper on my HD4, and the Ripmo seat tube is cut down by another 30mmI'm 185.5 cm with 90 cm inseam (6'1" / 35.5") and Ape Index of 0 on a Large with 32 mm stem. It's slightly too small, so I rolled my bars forward a few degrees from vertical. I figure a 45 mm stem would be perfect with the bars vertical.
I can kind of help, but from a size shift downwards.Very confusing parking lot test on a large Ripmo. I'm 183cm/6', 33" inseam, +1 ape index and I took the Ripmo for a pretty good spin (10 mins) around the streets near my LBS. Coming off my large HD4 which actually fits OK (I'd like more reach) it felt shorter and higher/less "in" the bike.
On my HD4 I run 780/35mm rise bars with a 50mm stem, and 170mm cranks, the Ripmo had 800/20mm bars, a 40mm, and 175mm cranks, and the only other thing that was a bit out was that bars were spaced up too high. I'm pretty confused because it should have still felt longer than my bike, but I ended up being in a very awkward position while standing/sprinting. I'm not sure I'll get a chance to try an XL and because the stack height is so high I'm not sure I could get my bars low enough.
Has anyone tried both bikes and could shed some light on this?
I'm the same height as Creg and had the same experience on a parking lot test - granted i was coming off a Ripley LS, not HD4. I think this is what transitioning to a modern geo bike feels like. The steep seat angle really negates that long reach when you're seated. I did a proper demo on a L in Santa Cruz and felt awesome after a 35 mile, 4,000' ride. It just takes some getting used to... Definitely opportunity to dial the cockpit with lower rise bars, 50-60mm stem, etc.Ripmo feeling smaller than the HD4 riding in the streets is no surprise. You have a shorter ETT with the shorter stem. And a very high stack with a lot of spacers.
Definitely a Medium you've got there. If you look at your bike next to mine (which is a large) you can see the difference in sweep, curve and bracing of the Top Tube/Seat Tube junction. That and the room above your shock piggyback is much smaller.I demo'd what I thought was a Medium and I loved the bike. So much that I bought one. After riding it a few times it almost feels cramped. I have a pic of the bike I demo'd. Is it possible to tell the size of the bike by looking? Size sticker is a bit gummed up and I am not sure now that I demod a medium... I'm thinking maybe it was a large.
Depends how aggressive you ride, but imo, yes... Too small.I'm almost 6 "5" is an xl going to be tight ?
Sent from my iPhone using Tapatalk Pro
