The Ripmo blipped on my radar. I'm 5'9" and right on the medium/large line. Anyone my height have any thoughts?
Any general sizing musings?
Same plan here, 6' 1.5'', 36.8'' inseam.6'1", on a XL Ripley, going XL Ripmo.
I run a high saddle, 83cm BB to top, so I mainly need the headtube height to keep the bars up and wheelbase to keep the front end down on climbs.
Planning on a 50mm stem
5' 10.5" tall. Bought a size large. Fits me perfectly. The bike Rips.
You will have to be mindful of your dropper and/or saddle choices on a large -- that Fox 150mm dropper tops out at 77.4 cm to the rails. The KS Lev Si 175mm in the GX build may not do it at 77.0 cm to the rails. (The two Bontraeger saddles I just measured were only 4.5 cm from rails to top.)...for the large which will mean there will be loads of seatpost to achieve the 82cm height I ride?
After reading the thread up and down you sound like you're 100% totally a LargeReady to order a Ripmo and trying to convince myself that a large is the right size to go with. I am 5'10.5 in with a 32.5 in inseam. Could a lucky owner of a large measure the distance between the nose of the saddle and the middle of the handlebar and indicate the stem length? It seems that this measurement has been reliable for me to pick frame sizes..... Thanks!!
I wouldn't worry about the seated position -- it's supposed to be different than you're used to. You'll keep your front down on climbs with your butt, not by weighting your bars. Feeling "cramped" isn't necessarily bad, just "different".So, for someone coming from a familiar bike, do you match the Reach (standing position) and go with a shorter ETT (seated position), or vice versa? Do you match the ETT (seated position) and go with a longer Reach (standing position)?
